Arduino Zero and Frequency Count Library
I am a design that works with the Atmega series MCUs but I want to upgrade to a SharpMemory LCD screen. Problem is I need the ram on the SAMD21 but I do not know how to adapt the Frequency Count library to work on the SAMD21.
I know the following is what needs to be edited, I need to define the SAMD and then make a subroutine to use the correct timer registers, but honestly its above my head. If there is anyone willing to help and or guide me in this I would greatly appreciate it.
/* FreqCount Library, for measuring frequencies
 * http://www.pjrc.com/teensy/td_libs_FreqCount.html
 * Copyright (c) 2014 PJRC.COM, LLC - Paul Stoffregen <paul@pjrc.com>
 * Version 1.1
 * Permission is hereby granted, free of charge, to any person obtaining a copy
 * of this software and associated documentation files (the "Software"), to deal
 * in the Software without restriction, including without limitation the rights
 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 * copies of the Software, and to permit persons to whom the Software is
 * furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
 * THE SOFTWARE.
#ifndef FreqCount_timers_h_
#define FreqCount_timers_h_
// Arduino Mega
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
  // #define COUNTER_USE_TIMER1 // T1 is not connected
  // #define COUNTER_USE_TIMER3 // T3 is not connected
  // #define COUNTER_USE_TIMER4 // T4 is not connected
  #define COUNTER_USE_TIMER5    // T5 is pin 47
  #define TIMER_USE_TIMER2
// Teensy 3.0 & 3.1 & LC
#elif defined(__MK20DX128__) || defined(__MK20DX256__) || defined(__MKL26Z64__) || defined(__MK64FX512__) || defined(__MK66FX1M0__)
  #define COUNTER_USE_LPTMR     // LPTMR is pin 13  (has LED connected)
  #define TIMER_USE_INTERVALTIMER
// Teensy 2.0
#elif defined(__AVR_ATmega32U4__)
  #define COUNTER_USE_TIMER1    // T1 is pin 11  (has LED connected)
  #define TIMER_USE_TIMER4H
// Teensy++ 1.0 & 2.0
#elif defined(__AVR_AT90USB646__) || defined(__AVR_AT90USB1286__)
  #define COUNTER_USE_TIMER1    // T1 is pin 6   (has LED connected)
  //#define COUNTER_USE_TIMER3  // T3 is pin 13
// Sanguino
#elif defined(__AVR_ATmega644P__) || defined(__AVR_ATmega644__)
// Arduino Duemilanove, Diecimila, LilyPad, Mini, Fio, etc
#elif defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)
  #define COUNTER_USE_TIMER1    // T1 is pin 5
#else
  #error "Unknown chip, please edit me with timer+counter definitions"
#endif
/*   Counter Hardware Abstraction             */
#if defined(COUNTER_USE_LPTMR) // 16 bit LPTMR on Freescale Kinetis
static inline void counter_init(void)
	SIM_SCGC5 |= SIM_SCGC5_LPTIMER;
	LPTMR0_CSR = 0;
	LPTMR0_PSR = 0b00000100; // bypass prescaler/filter
	LPTMR0_CMR = 0xFFFF;
	LPTMR0_CSR = 0b00100110; // counter, input=alt2, free running mode
	CORE_PIN13_CONFIG = PORT_PCR_MUX(3);
static inline void counter_start(void)
	LPTMR0_CSR = 0b00100111; // enable
static inline void counter_shutdown(void)
	LPTMR0_CSR = 0;
static inline uint16_t counter_read(void)
	LPTMR0_CNR = 0; // writing cause sync with hardware
	return LPTMR0_CNR;
static inline uint8_t counter_overflow(void)
	return (LPTMR0_CSR & 0x80) ? 1 : 0;
static inline void counter_overflow_reset(void)
	LPTMR0_CSR = 0b10100111;
#elif defined(COUNTER_USE_TIMER1) // 16 bit Timer 1 on Atmel AVR
static uint8_t saveTCCR1A, saveTCCR1B;
	saveTCCR1A = TCCR1A;
	saveTCCR1B = TCCR1B;
	TCCR1B = 0;
	TCCR1A = 0;
	TCNT1 = 0;
	TIFR1 = (1<<TOV1);
	TIMSK1 = 0;
	TCCR1B = (1<<CS12) | (1<<CS11) | (1<<CS10);
	TCCR1B = 0;
	TCCR1A = saveTCCR1A;
	TCCR1B = saveTCCR1B;
	return TCNT1;
	return TIFR1 & (1<<TOV1);
	TIFR1 = (1<<TOV1);
#elif defined(COUNTER_USE_TIMER3) // 16 bit Timer 3 on Atmel AVR
static uint8_t saveTCCR3A, saveTCCR3B;
	saveTCCR3A = TCCR3A;
	saveTCCR3B = TCCR3B;
	TCCR3B = 0;
	TCCR3A = 0;
	TCNT3 = 0;
	TIFR3 = (1<<TOV3);
	TIMSK3 = 0;
	TCCR3B = (1<<CS32) | (1<<CS31) | (1<<CS30);
	TCCR3B = 0;
	TCCR3A = saveTCCR3A;
	TCCR3B = saveTCCR3B;
	return TCNT3;
	return TIFR3 & (1<<TOV3);
	TIFR3 = (1<<TOV3);
#elif defined(COUNTER_USE_TIMER4) // 16 bit Timer 4 on Atmel AVR
static uint8_t saveTCCR4A, saveTCCR4B;
	saveTCCR4A = TCCR4A;
	saveTCCR4B = TCCR4B;
	TCCR4B = 0;
	TCCR4A = 0;
	TCNT4 = 0;
	TIFR4 = (1<<TOV4);
	TIMSK4 = 0;
	TCCR4B = (1<<CS42) | (1<<CS41) | (1<<CS40);
	TCCR4B = 0;
	TCCR4A = saveTCCR4A;
	TCCR4B = saveTCCR4B;
	return TCNT4;
	return TIFR4 & (1<<TOV4);
	TIFR4 = (1<<TOV4);
#elif defined(COUNTER_USE_TIMER5) // 16 bit Timer 5 on Atmel AVR
static uint8_t saveTCCR5A, saveTCCR5B;
	saveTCCR5A = TCCR5A;
	saveTCCR5B = TCCR5B;
	TCCR5B = 0;
	TCCR5A = 0;
	TCNT5 = 0;
	TIFR5 = (1<<TOV5);
	TIMSK5 = 0;
	TCCR5B = (1<<CS52) | (1<<CS51) | (1<<CS50);
	TCCR5B = 0;
	TCCR5A = saveTCCR5A;
	TCCR5B = saveTCCR5B;
	return TCNT5;
	return TIFR5 & (1<<TOV5);
	TIFR5 = (1<<TOV5);
#endif // COUNTER_USE_***
static inline void timer_start(void)
	TCCR4B = startTCCR4B;
	TIMSK4 = (1<<TOIE4);
static inline void timer_shutdown(void)
	TCCR4B = 0;
	TIMSK4 = 0;
	OCR4C = saveOCR4C;
	TCCR4C = saveTCCR4C;
	TCCR4D = saveTCCR4D;
	TCCR4E = saveTCCR4E;
#define TIMER_ISR_VECTOR TIMER4_OVF_vect
#define TIMER_LATENCY_CYCLES 34
#endif // TIMER_USE_***
static inline void timer_isr_latency_delay(void)
#ifdef TIMER_LATENCY_CYCLES
#ifdef __AVR__
	uint8_t cycles_times_3 = TIMER_LATENCY_CYCLES / 3;
	asm volatile(
		"L_%=_loop:"
		"subi   %0, 1"		"\n\t"
		"brne   L_%=_loop"	"\n\t"
		: "+d" (cycles_times_3)
		: "0" (cycles_times_3)
#endif
#endif
/*   Board Specific Interrupts (to hog)       */
static inline void disable_other_interrupts(void)
static inline void restore_other_interrupts(void)
#endif
Removed some of the code to fit into post***
I am interested as well on this!
