Arduino zero and "shutdown command invoked"
I have sketch that runs on the UNO. I upgraded to a ZERO. When I upload that sketch to the ZERO, it doesn't run. I have a lot of print statements that I should see, but I don't see anything. Here is the last bit of what I see in the (progress??) window at the bottom of the Arduino IDE (1.6.7)
Info : at91samd21g18.cpu: hardware has 4 breakpoints, 2 watchpoints
target state: halted
target halted due to debug-request, current mode: Thread
xPSR: 0x61000000 pc: 0x00000858 msp: 0x200023a0
** Programming Started **
auto erase enabled
Info : SAMD MCU: SAMD21G18A (256KB Flash, 32KB RAM)
Warn : Adding extra erase range, 00000000 to 0x00001fff
wrote 24576 bytes from file C:\Users\roujesky\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp/BlinkWithoutDelay.ino.bin in 2.941169s (8.160 KiB/s)
** Programming Finished **
** Verify Started **
verified 8340 bytes in 0.710040s (11.471 KiB/s)
** Verified OK **
** Resetting Target **
am I supposed to see "shutdown command invoked"??
I am at a loss as to what to do. I read the Arduino Zero -- Getting Started....
thanks!
Please don't create multiple posts about the same thing: http://forum.arduino.cc/index.php?topic=383218
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Your other thread deleted.
  • Moderator
sorry, could not find that post and wasnt sure it got posted
I have the same issue and the link provided can not be accessed (I am logged in).
Thank You
Asher1fri:
The link was just the duplicate post which has been deleted.
after uploading my arduino M0 pro i can read on IDE 1.7.9 “shut down command invoked” is it ok?
