Arduino Zero: Baud Rate
The maximum baud rate on arduino serial monitor is 250000. I am using Arduino Zero and was wondering if I could increase the baud rate when I use RealTerm instead of Arduino serial monitor.
Thanks
I have used 1,000,000 Baud with an Uno.
I am not familiar with the Zero but if it has the same sort of USB system as the Leonardo it will work at the full USB speed which is considerably faster than 1M baud.
Be aware that the USB system performs poorly when handling only a few bytes at a time - even with a high baud rate the overall throughput can be slow. You need to do some tests.
...R
