configuration.h:
#ifndef CONFIGURATION_H_
#define CONFIGURATION_H_
#include "Arduino.h"
/* ----- General configuration -----*/
// Activate USB serial interface for ARM processor types.
// put this first
#define USE_USBCON
// Specify the CPU frequency of the controller.
#define CPU_FREQ_HZ 48e6
/* ----- serial2 configuration ---- */
// Serial2 (on Sercom1) using digital pins 12 (Rx) and 10 (Tx).
// [check here](https://forum.arduino.cc/t/arduino-zero-softwareserial-library/328806/6)
#define SERIAL2_RX_PIN (34ul) // Pin description number for PIO_SERCOM on D12
#define SERIAL2_TX_PIN (36ul) // Pin description number for PIO_SERCOM on D10
#define SERIAL2_RX_PAD (SERCOM_RX_PAD_3) // SERCOM pad 3
#define SERIAL2_TX_PAD (UART_TX_PAD_2) // SERCOM pad 2
/* ----- sensors configuration ---- */
// arduino system time beginning
#define TIME_BASE 1621258639
//// PPS
#define PPS_TOPIC "/rov/synchronizer/pps/"
#define PPS_TRIGGER_PIN 13
#define PPS_TIME_DELAY 10 // send pps time after this delay
#endif // CONFIGURATION_H_
Pps.h:
#ifndef PPS_H_
#define PPS_H_
#include <ros.h>
#include <sensor_msgs/TimeReference.h>
#include <std_msgs/String.h>
#include <time.h>
#include "configuration.h"
class Pps {
public:
Pps(ros::NodeHandle *nh, const String &topic, const uint8_t trigger_pin, HardwareSerial* serial);
void begin();
void setTimeNow();
void setNotAvailable();
bool isAvailable() { return available_; };
void encodeTimeGPS(uint32_t curr_time);
void encodeTimeROS(uint32_t curr_time);
void publishTimeROS();
void publishTimeGPS();
uint32_t getOffset() { return micro_offset_; };
uint32_t getTime() { return time_; };
void setClock(bool utc_clock, uint32_t start_time, uint32_t curr_time_base);
void publish();
private:
// hardware pin in arduino to generate pps
const uint8_t trigger_pin_;
uint32_t micro_offset_;
uint32_t time_;
// ROS
ros::NodeHandle *nh_;
ros::Publisher publisher_time_;
ros::Publisher publisher_info_;
String topic_time_;
String topic_info_;
sensor_msgs::TimeReference pps_time_msg_;
std_msgs::String pps_info_msg_;
// pps time used in Jetson
Stream* serial2_;
char gpgga[100];
char gpgsa[100];
char gpgsv_1[100];
char gpgsv_2[100];
char gprmc[100];
char gpzda[100];
//// Clock
volatile bool utc_clock_;
volatile uint32_t start_time_;
volatile uint32_t curr_time_base_;
// pps time used in microstrain ahrs for tims sync
volatile bool available_;
#endif // PPS_H_
Pps.cpp:
#include "Pps.h"
Pps::Pps(ros::NodeHandle *nh, const String &topic, const uint8_t trigger_pin, HardwareSerial* serial)
: nh_(nh), trigger_pin_(trigger_pin), available_(false), micro_offset_(0),
topic_time_(topic+"time"), publisher_time_(topic_time_.c_str(), &pps_time_msg_),
topic_info_(topic+"info"), publisher_info_(topic_info_.c_str(), &pps_info_msg_),
curr_time_base_(0), utc_clock_(false), start_time_(0)
publisher_time_ = ros::Publisher("/rov/synchronizer/pps/time", &pps_time_msg_);
publisher_info_ = ros::Publisher("/rov/synchronizer/pps/info", &pps_info_msg_);
nh_->advertise(publisher_time_);
nh_->advertise(publisher_info_);
serial2_ = serial;
void Pps::begin() {
/* ----- Serial setup -----*/
/** Set timer TCC2 generate a 100ms pulse every second on D13 (PA17) **/
// Enable D13's peripheral multiplexer
PORT->Group[g_APinDescription[trigger_pin_].ulPort].PINCFG[g_APinDescription[trigger_pin_].ulPin].bit.PMUXEN = 1;
// Set D13 multiplexer switch to position
PORT->Group[g_APinDescription[trigger_pin_].ulPort].PMUX[g_APinDescription[trigger_pin_].ulPin >> 1].reg |= PORT_PMUX_PMUXO_E;
TCC2->WAVE.reg = TCC_WAVE_WAVEGEN_NPWM; // Configure the TCC2 timer for normal PWM mode
while (TCC2->SYNCBUSY.bit.WAVE); // Wait for synchronization
TCC2->PER.reg = 46874; // Set the TCC2 PER register to generate a 1 second period
while (TCC2->SYNCBUSY.bit.PER); // Wait for synchronization
TCC2->CC[1].reg = 4688; // Set the TCC2 CC1 register to generate a duty cycle of 10% (100ms)
while (TCC2->SYNCBUSY.bit.CC1); // Wait for synchronization
// NVIC_SetPriority(TCC2_IRQn, 0); // Set the Nested Vector Interrupt Controller (NVIC) priority for TCC2 to 0 (highest)
// NVIC_EnableIRQ(TCC2_IRQn); // Connect TCC2 to Nested Vector Interrupt Controller (NVIC)
TCC2->INTENSET.reg = TCC_INTENSET_OVF; // Enable TCC2 overflow (OVF) interrupts
TCC2->CTRLA.reg = TCC_CTRLA_PRESCSYNC_PRESC | // Reset timer on the next prescaler clock
TCC_CTRLA_PRESCALER_DIV1024; // Set prescaler to 1024, 48MHz/1024 = 46875kHz
TCC2->CTRLA.bit.ENABLE = 1; // Enable the TCC2 timer
while (TCC2->SYNCBUSY.bit.ENABLE); // Wait for synchronization
void Pps::setClock(bool utc_clock, uint32_t start_time, uint32_t curr_time_base) {
utc_clock_ = utc_clock;
start_time_ = start_time;
curr_time_base_ = curr_time_base;
void Pps::setTimeNow() {
if (TCC2->INTFLAG.bit.OVF && TCC2->INTENSET.bit.OVF) // Optionally check for overflow (OVF) interrupt
TCC2->INTFLAG.bit.OVF = 1; // Clear the overflow (OVF) interrupt flag
time_ = micros();
available_ = true;
void Pps::setNotAvailable() {
available_ = false;
void Pps::publish() {
if(isAvailable()) {
uint32_t t1 = micros();
//// get time duration after UTC clock is set
uint32_t time_aft_utc, latest_sec;
time_aft_utc = time_ - start_time_;
//// get second part
if(utc_clock_)
latest_sec = curr_time_base_ + time_aft_utc / 1000000;
latest_sec = TIME_BASE + time_aft_utc / 1000000;
//// get microsecond part
micro_offset_ = time_aft_utc % 1000000;
//// encode time format
encodeTimeROS(latest_sec);
encodeTimeGPS(latest_sec);
//// publish time
publishTimeROS();
publishTimeGPS();
//// set not avaiable
setNotAvailable();
uint32_t dt = micros() - t1;
String str = String(dt);
pps_info_msg_.data = str.c_str();
publisher_info_.publish(&pps_info_msg_);
void Pps::encodeTimeROS(uint32_t curr_time) {
pps_time_msg_.header.stamp = ros::Time(curr_time, micro_offset_*1000);
pps_time_msg_.header.frame_id = "arduino";
pps_time_msg_.time_ref = pps_time_msg_.header.stamp;
pps_time_msg_.source = pps_time_msg_.header.frame_id;
// NMEA example: http://aprs.gids.nl/nmea/
// NMEA Checksum Calculator: https://nmeachecksum.eqth.net/
// Epoch time: https://www.epochconverter.com/
// real data:
// $GPGGA,205331.000,4129.4837,N,07125.3140,W,2,07,1.04,28.2,M,-34.4,M,0000,0000*6E
// $GPGSA,A,3,31,22,32,25,10,12,29,,,,,,1.32,1.04,0.81*03
// $GPGSV,2,1,08,31,75,308,43,32,59,105,44,22,38,293,37,25,37,053,26*71
// $GPGSV,2,2,08,29,12,098,29,10,12,170,32,12,09,037,36,49,01,099,34*76
// $GPRMC,205331.000,A,4129.4837,N,07125.3140,W,0.01,260.08,011121,,,D*71
// $GPZDA,205331.000,01,11,2021,,*50
void Pps::encodeTimeGPS(uint32_t curr_time) {
/****** convert Epoch to UTC ******/
time_t rawtime = curr_time;
struct tm ts;
char utc_time[7];
char utc_date[7];
char utc_DATE[9];
char dd[3];
char mm[3];
char YY[5];
// get time
ts = *localtime(&rawtime);
strftime(utc_time, sizeof(utc_time), "%H%M%S", &ts);
strftime(utc_date, sizeof(utc_date), "%d%m%y", &ts);
// for ZDA
strftime(utc_DATE, sizeof(utc_DATE), "%d%m%Y", &ts);
strncpy(dd, utc_DATE + 0, 2);
strncpy(mm, utc_DATE + 2, 2);
strncpy(YY, utc_DATE + 4, 4);
dd[2]='\0';
mm[2]='\0';
YY[4]='\0';
char end[5];
int size, checksum;
/****** GPGGA ******/
// $GPGGA,092751.00,41.49,N,71.25,W,1,08,1.03,61.7,M,55.3,M,,*46<CR><LF>
// 1 2 3 4 5 6 7 8 9 10 11 12131415 16 17
// $GPGGA,hhmmss.ss,xx.xx,a,xx.xx,a,x,xx,x.xx,xx.x,M,xx.x,M,,*46<CR><LF>
// 1) UTC time: 09:27:51
// 2) Latitude: 41.49
// 3) North/South: N
// 4) Longitude: 71.25
// 5) East/West: W
// 6) GPS Quality: 0=no fix, 1=GPS fix, 2=Dif. GPS fix
// 7) Number of satellites in use
// 8) Horizontal Dilution of Precision (HDOP): Relative accuracy of horizontal position
// 9) Antenna altitude above mean-sea-level:
// 10) M: units of antenna altitude, meters
// 11) Height of geoid above WGS84 ellipsoid
// 12) M: units of geoidal separation, meters
// 13) Blank: Time since last DGPS update
// 14) Blank: DGPS reference station id
// 15) Checksum between $ and *: 46
// 16) <CR>: Carriage return
// 17) <LF>: Line feed, end delimiter 2
checksum = 0;
size = sprintf(gpgga, "$GPGGA,%s.00,4129.4837,N,07125.3140,W,2,07,1.04,28.2,M,-34.4,M,,", utc_time);
for(int i=1;i<size;i++) {
checksum^=gpgga[i];
sprintf(end,"*%02X%c%c",checksum,13,10);
strcat(gpgga,end);
/****** GPGSA ******/
// $GPGSA,A,3,10,07,05,02,29,04,08,13,,,,,1.72,1.03,1.38*0A<CR><LF>
// 1 2 3 14 15 16 17 18 19 20
// $GPGSA,A,x,xx,xx,xx,xx,xx,xx,xx,xx,,,,,x.xx,x.xx,x.xx*0A<CR><LF>
// 1) Mode: M (Manual, forced to operate in 2D or 3D); A (Automatic, 3D/2D)
// 2) Mode: 1 (Fix not available); 2 (2D); 3 (3D)
// 3-14) IDs: SVs used in position fix (null for unused fields)
// 15) PDOP
// 16) HDOP
// 17) VHOP
// 18) Checksum between $ and *: 0A
// 19) <CR>: Carriage return
// 20) <LF>: Line feed, end delimiter
checksum = 0;
size = sprintf(gpgsa, "$GPGSA,A,3,31,22,32,25,10,12,29,,,,,,1.32,1.04,0.81");
checksum^=gpgsa[i];
strcat(gpgsa,end);
/***** GPGSV *****/
// $GPGSV,3,1,11,10,63,137,17,07,61,098,15,05,59,290,20,08,54,157,30*70
// 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
// 1) Totall number of messages
// 2) Messager number
// 3) Total number of SVs in view
// 4) SV PRN number
// 5) Elevation in degrees, 90 maximum
// 6) Azimuth, degrees from true north, 000 to 359
// 7) SNR, 00-99 dB (null when not tracking)
// 8-11) next SV, same as 4-7)
// 12-15) next SV, same as 4-7)
// 16-19) next SV, same as 4-7)
// 1st
checksum = 0;
size = sprintf(gpgsv_1, "$GPGSV,2,1,08,31,75,308,43,32,59,105,44,22,38,293,37,25,37,053,26");
checksum^=gpgsv_1[i];
strcat(gpgsv_1,end);
// 2nd
checksum = 0;
size = sprintf(gpgsv_2, "$GPGSV,2,2,08,29,12,098,29,10,12,170,32,12,09,037,36,49,01,099,34");
checksum^=gpgsv_2[i];
strcat(gpgsv_2,end);
/****** GPRMC ******/
// $GPRMC,092751.00,A,41.49,N,71.25,W,1.94,66.66,280511,004.2,W,D*5C<CR><LF>
// 1 2 3 4 5 6 7 8 9 10 1112 1314 15
// $GPRMC,hhmmss.ss,A,xx.xx,N,xx.xx,W,x.xx,xx.xx,ddmmyy,xxx.x,W,D*HH<CR><LF>
// 2) Validity: A-ok, V-invalid
// 3) Latitude: 41.49
// 4) North/South: N
// 5) Longitude: 71.25
// 6) East/West: W
// 7) Speed in knots: 1.94 ~ 1m/s
// 8) True north: 66.66 (fake)
// 9) UTC Date: 28 May 2011
// 10) Magnetic Declination (Variation): 004.2(fake)
// 11) East/West: W
// 12) Positioning system mode indicator: A (Autonomous), D (Differential), E (Estimated (dead reckoning) mode), M (Manual input), N (Data not valid)
// 13) Checksum between $ and *: 5C
// 14) <CR>: Carriage return
// 15) <LF>: Line feed, end delimiter
checksum = 0;
size = sprintf(gprmc, "$GPRMC,%s.000,A,4129.4837,N,07125.3140,W,0.01,260.08,%s,,,D", utc_time, utc_date);
checksum^=gprmc[i];
strcat(gprmc,end);
/****** GPZDA ******/
// $GPZDA,205331.000,01,11,2021,,*50<CR><LF>
// $GPZDA,hhmmss.sss,dd,mm,yyyy,xx,xx*50<CR><LF>
// 1) UTC time: 20:53:31
// 2) Day: 01
// 3) Month: 11(Nov.)
// 4) Year: 2021
// 5) Local zone description, 00 to +/- 13 hours
// 6) Local zone minutes description (same sign as hours)
// 7) Checksum between $ and *: 5C
// 8) <CR>: Carriage return
// 9) <LF>: Line feed, end delimiter
checksum = 0;
size = sprintf(gpzda, "$GPZDA,%s.000,%s,%s,%s,,", utc_time, dd, mm, YY);
checksum^=gpzda[i];
strcat(gpzda,end);
//// send time to AHRS by ROS sensor_msgs/TimeReference msg
void Pps::publishTimeROS() {
// send pps time delay some time(30ms) after PPS is sent
// delay(PPS_TIME_DELAY);
// send time to AHRS by ROS Message
publisher_time_.publish( &pps_time_msg_ );
//// send time to Jetson by NMEA String
void Pps::publishTimeGPS() {
serial2_->write(gpgga, sizeof(gpgga));
serial2_->write(gpgsa, sizeof(gpgsa));
serial2_->write(gpgsv_1, sizeof(gpgsv_1));
serial2_->write(gpgsv_2, sizeof(gpgsv_2));
serial2_->write(gprmc, sizeof(gprmc));
serial2_->write(gpzda, sizeof(gpzda));
test_pps.ino:
// Import all settings for the chosen sensor configuration.
// Arduino
#include <math.h>
// ROS
#include <ros.h>
#include <std_msgs/UInt8.h>
#include <std_msgs/UInt16.h>
#include <std_msgs/UInt32.h>
#include <std_msgs/Bool.h>
#include <std_msgs/Float32MultiArray.h>
// PPS time
#include "Pps.h"
#include "helper.h"
//// Instantiate the Serial2 class
Uart Serial2(&sercom1, SERIAL2_RX_PIN, SERIAL2_TX_PIN, SERIAL2_RX_PAD, SERIAL2_TX_PAD);
// some global variables
volatile uint16_t offset = 0;
/* ==================== ROS ==================== */
ros::NodeHandle nh;
// published messages
std_msgs::String str_msg;
// publishers for for system level
ros::Publisher msg_pub("/rov/synchronizer/system", &str_msg);
// callback for reset flag from onboard computer
void resetCallback(const std_msgs::Bool &msg) { NVIC_SystemReset(); }
// callback for setting arduino clock
void clockCallback(const std_msgs::UInt32 &msg);
// subscribers for system level
ros::Subscriber<std_msgs::Bool> reset_sub("/rov/synchronizer/reset_system", &resetCallback);
ros::Subscriber<std_msgs::UInt32> clock_sub("/rov/synchronizer/reset_clock", &clockCallback);
/* ==================== Objects ==================== */
//// Instantiate PPS object
Pps pps(&nh, PPS_TOPIC, PPS_TRIGGER_PIN, &Serial2);
/* ----- Sub-system Setting ----- */
// start serial2 to send NMEA to Jetson
Serial2.begin(115200);
Serial2.setTimeout(10);
/* ----- ROS ----- */
//// init
nh.getHardware()->setBaud(250000);
nh.initNode();
//// sub
nh.subscribe(reset_sub);
nh.subscribe(clock_sub);
//// pub
nh.advertise(msg_pub);
/* ----- PPS Setting ----- */
// feed GCLK0 to TCC2 and TC3 timers
REG_GCLK_CLKCTRL = static_cast<uint16_t>(
GCLK_CLKCTRL_CLKEN | GCLK_CLKCTRL_GEN_GCLK0 | GCLK_CLKCTRL_ID_TCC2_TC3);
while (GCLK->STATUS.bit.SYNCBUSY);
// enable InterruptVector
// pps.begin();
//// heandle time message publishing, take 0.002 second
pps.publish();
nh.spinOnce();
/* ==================== Arduino Hardware Interrupts ==================== */
void SERCOM1_Handler()
Serial2.IrqHandler();
void TCC2_Handler() {
pps.setTimeNow();
// offset = pps.getOffset();
// check Epoch time: https://www.epochconverter.com/
void clockCallback(const std_msgs::UInt32 &msg) {
if(msg.data > TIME_BASE) {
//// Info to onboard computer
str_msg.data = "#system:Arduino clock reset as UTC";
msg_pub.publish(&str_msg);
//// start PPS generation
pps.begin();
//// record arduino clock received UTC clock
uint32_t start_time = micros();
bool utc_clock = true;
uint32_t curr_time_base = msg.data;
//// setup pps clock
pps.setClock(utc_clock, start_time, curr_time_base);
else {
str_msg.data = "#system:sent clock is too old";
