I've recently installed the Arduino IDE on a Windows 7 machine and have been encountering the following problem when compiling for my Arduino Zero with this setup:
fork/exec C:\Users\shane.lillie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-gcc.exe: Access is denied.
I've tried reinstalling the Arduino IDE, the Arduino Zero board tools, and the libraries I've been using but none of that seems to fix the problem. It works fine on a different machine (using Windows 10) so it seems like it's something with this particular installation, but I can't for the life of me figure out what it would be. This is the full output from the command that seems to be the problem:
"C:\Users\shane.lillie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-gcc" "-LC:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp" -Os -Wl,--gc-sections -save-temps "-TC:\Users\shane.lillie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.2\variants\arduino_zero/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp/coffeenotif.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp/coffeenotif.ino.elf" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\sketch\coffeenotif.ino.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\sketch\es_config.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\sketch\es_core.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\sketch\es_ntp.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\sketch\es_slack.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\sketch\es_udp.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\sketch\es_wifi.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\SD\File.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\SD\SD.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\SD\utility\Sd2Card.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\SD\utility\SdFile.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\SD\utility\SdVolume.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\SPI\SPI.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\WiFi.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\WiFiClient.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\WiFiSSLClient.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\WiFiServer.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\WiFiUdp.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\bsp\source\nm_bsp_arduino.c.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\bsp\source\nm_bsp_arduino_avr.c.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\bus_wrapper\source\nm_bus_wrapper_samd21.cpp.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\common\source\nm_common.c.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\driver\source\m2m_hif.c.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\driver\source\m2m_ota.c.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\driver\source\m2m_periph.c.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\driver\source\m2m_wifi.c.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\driver\source\nmasic.c.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\driver\source\nmbus.c.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\driver\source\nmdrv.c.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\driver\source\nmi2c.c.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\driver\source\nmspi.c.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\driver\source\nmuart.c.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\socket\source\socket.c.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\WiFi101\socket\source\socket_buffer.c.o" "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp\libraries\RTCZero\RTCZero.cpp.o" -Wl,--start-group -lm "C:\Users\SHANE~1.LIL\AppData\Local\Temp\build7a261f7dfa3c15e5503bf95be3d600d5.tmp/core\core.a" -Wl,--end-group
I figured maybe changing my environment TEMP/TMP directories to C:\Temp would fix it, but it did not. I'm not sure what else there is I can do here.
