Arduino Zero I2C Master setClock() value
Hi all,
I am setting up a Zero with two I2C interfaces. The default Wire interface is being used as a slave while I added an I2C interface as a master to pins D3 and D4 using sercom2. For now I wrap the master/slave interfaces around to each other on the same Zero for testing. Pull ups are included in my wiring. While this works, I find that the setClock function does not alter the master's frequency the same it did on AVR devices. For example, using:
I2CMaster.setClock(400000L);
results in a (approximate) 340kHz clock speed. The closest I can get to 400 kHz is by using:
I2CMaster.setClock(462000L);
and results in a (approximate) 390kHz clock speed.
Trial and error of different values has gotten me close to 400Khz. I've attached a sketch below that makes this easy to replicate. Any info on how to use setClock on the Zero is appreciated.
Thanks,
Lenny
#include <Wire.h>
#include "wiring_private.h" // pinPeripheral() function
uint8_t message_count = 0;
uint8_t myBuff[] = {0x00, 0x00, 0x00};
uint8_t i2cMessage[32] = {0};
volatile boolean timer1HzFired = false;
uint8_t interrupt_count = 0;
volatile boolean LEDON = false;
TwoWire I2CMaster(&sercom2, 4, 3);
  /* Init the serial port */
  Serial.begin(115200);         // Init UART at 115.2 kbps (USB COM Port)
  Serial.setTimeout(1);         // 1 ms timeout on reads from USB COM Port
  // while the serial stream is not open, do nothing (useful for seeing setup prints):
  while (!Serial) ;
  Serial.println("Serial port init complete");
  Wire.begin(0x0C);             // Init I2C with controller slave address
  Wire.onRequest(requestEvent); // Register interrupt call back for an I2C read
  Wire.onReceive(receiveEvent); // Register interrupt call back for an I2C write
  Serial.println("Wire init complete");
   *  Used as a visual indication of the 1Hz timing
  pinMode(LED_BUILTIN, OUTPUT);
  Serial.println("LED init complete");
  I2CMaster.begin();
  I2CMaster.setClock(465000L);
  // Assign pins 4 & 3 to SERCOM functionality
  pinPeripheral(4, PIO_SERCOM_ALT);
  pinPeripheral(3, PIO_SERCOM_ALT);
  Serial.println("I2C Master init complete");
    if (millis() % 1000 == 0) {
    timer1HzFired = true;
  if (timer1HzFired) {
    Serial.println("1Hz Flag True");
    callback1Hz();
void sendMessage(const uint8_t *buf, uint8_t size)
  uint8_t i2cAddress = buf[0];
  for (int j = 0; j < size; j++) {
    i2cMessage[j] = buf[j+1];
  I2CMaster.beginTransmission(i2cAddress);
  I2CMaster.write(i2cMessage,(size-1));
  I2CMaster.endTransmission();
// onRequest Interrupt Handler
void requestEvent() {
// onReceive Interrupt Handler
void receiveEvent(int bytesReceived) {
// Callback at 1Hz
void callback1Hz()
   * The LED will be on for 1 second and then off for 1 second
  if (LEDON) {
    digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
    Serial.println("LED Off");
  else {
    digitalWrite(LED_BUILTIN, HIGH);    // turn the LED on by making the voltage HIGH
    Serial.println("LED On");
  LEDON = !LEDON;
  message_count++;
  myBuff[0] = 0x0C;
  myBuff[1] = 0xFF;
  myBuff[2] = message_count;
  sendMessage(myBuff, 3);
