I am having monochrome i2c ole 128x32 display and when using arduino uno to search for i2c device I can find it,but when I switch to arduino zero i2c scanner it seems that it can't find it.
I notice a similar problem using the i2c_scanner with the Arduino Zero. It doesn't work with this board(?).
I have the SDA and SCL pins on the Ardunio Zero connected to two slaves (OV7670 and MPU-6050) as shown below, with a 4.7kOhm pull up to 3.3V on each line.
I assume the following:
OV7670 is at 0x42 and 0x43
MPU6050 is at 0x68
but I want to verify with i2c_scanner.
I ran the i2c_scanner code and it returns "Unknow error at address" for all addresses. I tried disconnecting each of the slaves to run the i2c_scanner again with just one slave on the bus, but same problem for each slave device.
I can communicate with the MPU6050 via I2C knowing the address, but the OV7670 is giving me trouble...that's for another thread.
I tried playing around with the i2c_scanner code (see below) to see if there is another way of finding valid addresses. I don't know if this would work on other boards, as I only have an Arduino Zero, but I notice it hangs inside of Wire.requestFrom(address, numBytes) when the address isn't valid. I welcome input. Especially on how to step out of this function when the program is hung inside waiting.
One more note, I'm new to Arduino and haven't found a better way to debug than using the serial monitor.
Wire.begin(); //join i2c bus
for(address = 104; address < 127; address++ )//Start at known valid address
bool flag = 1;
Serial.print("checking address ");
Serial.println(address);
Wire.requestFrom(address,10);//guessing 10 bytes is enough
Serial.println("debug1");
while(Wire.available())
Serial.println("debug2");
int b = Wire.read();
Serial.println(b, HEX);
flag = 0;
if(flag)//wire not available
Serial.println("nothing at this address");
Serial.println("debug3");
error = Wire.endTransmission();
Serial monitor output: I2C Scanner Scanning... Unknow error at address 0x68 Unknow error at address 0x69 . . . Unknow error at address 0x7D Unknow error at address 0x7E No I2C devices found checking address 104 debug1 debug2 A debug2 28 debug2 6F debug2 6F debug2 94 debug2 66 debug2 0 debug2 0 debug2 0 debug2 0 debug3 checking address 105
