I am trying to use some counters as clocks. I need a high precision clock that needs to count real time seconds with better than 0.5 µs precision and can count up to a few thousand seconds. Also two clocks that are software gated with the same precision. I am planning to use the 48 MHz PLL locked clock and with a divisor of 9 that gives me the required precision (5.33333... MHz) and I presume, its locked to a 32. 768 kHz watch crystal, good accuracy too.
I shamelessly hacked Marcus Balder's/MartinL's code (Arduino ZERO timer reading counter value - #3 by MartinL - Arduino Zero - Arduino Forum) and made the attached sketch which basically is a 16 counter that takes the clock and produces an interrupt every 1.2288000E-2 s (supertick) that are counted and printed.
This works fine on TC3 with the attached sketch (I needed to make one small modification as some definition was not made for GCLK.) I really want to minimise dead time spent in interrupt servicing so it would be a good idea to use 32-bit rather than 16 bit counters to generate the interrupts so that the dead-time is reduced. As TC4 and TC5 use a common clock this blocks TC5 for me. TC6 and TC7 are available it seems. However, I cannot get the sketch to work with TC6 because the compiler claims TC6 is not defined. I am using the 1.7.7 IDE from Arduino.org and a M0 PRO.
So to my humble, and perhaps dumb, questions:
Which TCC and TC are defined in the Arduino IDE?
Which TCC and TC can be reassigned and used safely? (TC4 seems to be used for delayMicroseconds() as this shares a common 48 MHz clock with TC5 I presume this is blocked too. ) I don not intend PWM for analogue output.
How to I define TC6 and TC7 so I can use them as a 32-bit counter pair?
Harry J Whitlow
// Real time clock with better than 0.5 µs accuracy
volatile uint32_t realTcount = 0x0 ; // Counter for superticks (overflow interrupts)
setclockTC3();
setCounterTC3();
This is test code that counts to 10 s then resets and waits 3s to test
reset, start and stop functions on TC3.
delay(250);
Serial.print(realTime(), 7);
double val = realTime();
if( int(val) >= 10)
resetStartTC3(); // reset so never gets above 10 s
stopTC3();
delay(3000); //wait 3 sec
startTC3();
void TC3_Handler() // Interrupt on overflow
TcCount16* TC = (TcCount16*) TC3; // get timer struct
realTcount++; // Increment the supertick register
TC->INTFLAG.bit.OVF = 1; // writing a one clears the flag ovf flag
Get the real time in seconds.
double realTime()
double realTime = (realTcount * 1.2288E-2) + (REG_TC3_COUNT16_COUNT * 1.875E-7) ;;
return realTime;
Setup the Generic clock register
void setclockTC3()
// Setup and enable clock for TC
REG_GCLK_GENDIV = GCLK_GENDIV_DIV(9) | // Divide the 48MHz system clock by 9 = 5.33333MHz
GCLK_GENDIV_ID(5); // Set division on Generic Clock Generator (GCLK) 5
while (GCLK->STATUS.bit.SYNCBUSY); // Wait for synchronization
REG_GCLK_GENCTRL = GCLK_GENCTRL_IDC | // Set the duty cycle to 50/50 HIGH/LOW
GCLK_GENCTRL_GENEN | // Enable GCLK 5
GCLK_GENCTRL_SRC_DFLL48M | // Set the clock source to 48MHz
GCLK_GENCTRL_ID(5); // Set clock source on GCLK 5
REG_GCLK_CLKCTRL = GCLK_CLKCTRL_CLKEN | // Enable the generic clock...
GCLK_CLKCTRL_GEN_GCLK5 | // ....on GCLK5
// Hack to overcome define problem in next line!!!
0x1B; // Feed the GCLK5 to TCC2 and TC3
void setCounterTC3()
// The type cast must fit with the selected timer mode
TC->CTRLA.reg &= ~TC_CTRLA_ENABLE; // Disable TC
while (TC->STATUS.bit.SYNCBUSY == 1); // wait for sync
TC->CTRLA.reg |= TC_CTRLA_MODE_COUNT16; // Set Timer counter Mode to 16 bits
TC->CTRLA.reg |= TC_CTRLA_WAVEGEN_NFRQ; // Set TC as normal Normal Frq
TC->CTRLA.reg |= TC_CTRLA_PRESCALER_DIV1; // Set perscaler
// Interrupts
TC->INTENSET.reg = 0; // disable all interrupts
TC->INTENSET.bit.OVF = 1; // enable overfollow interrup
// Enable InterruptVector
NVIC_EnableIRQ(TC3_IRQn);
// Enable TC
TC->CTRLA.reg |= TC_CTRLA_ENABLE;
void resetStartTC3()
realTcount = 0x00; // Zero superclicks
TC->CTRLBSET.reg |= TC_CTRLBCLR_CMD_RETRIGGER; // restart
void stopTC3()
TC->CTRLBSET.reg |= TC_CTRLBSET_CMD_STOP; // Stop counter
void startTC3()
TC->CTRLBSET.reg |= TC_CTRLBSET_CMD_RETRIGGER; // Start
