Arduino Zero promlem
I tried to download code, but it is not successful.
I touched Atmel chip it was very hot.
the "L" LED is bright.
The message shoe as below:
Arduino:1.6.10 (Windows 7), 板子:"Arduino/Genuino Zero (Programming Port)"
Open On-Chip Debugger 0.9.0-gd4b7679 (2015-06-10-22:24)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
debug_level: 0
adapter speed: 500 kHz
adapter_nsrst_delay: 100
cortex_m reset_config sysresetreq
in procedure 'program'
in procedure 'init' called at file "embedded:startup.tcl", line 473
in procedure 'ocd_bouncer'
** OpenOCD init failed **
shutdown command invoked
上傳草稿碼時發生錯誤
option enabled in File -> Preferences.
Please help me how to fix this problem?
thanks,
Darren
I don't know what you did to it, but the Atmel chip should not get hot in operation. Usually if a microcontroller is getting hot to the touch, it's damaged. Many electronic components fail in a "near short" state that results in the part heating up.
I checked 3.3V output pin, it is short status. How to get or buy zero "ATSAMD21G18, 32-Bit ARM Cortex M0+" chip?
