OK, there are thousands of people with this problem, none of the answers seem to help me.
I have an Anet LCD2004 display and this code works on my Uno, but not on my Zero. The UNO shows the responses expected in the code, the Zero shows gibberish. (any photo will do for example, "alien text" is how one person described it.)
I'm wired from the 10 pin ribbon to a protoboard shield, all the wires go to the correct places (gnd, 5v, A0, 12, 11, 5, 4, 3, 2, brightness is on a resistive divider.)
Like I say, it works on the UNO, shows garbage on the Zero. Is this down to voltages? Are there default pin settings I have to override?
Any suggestions?
//Sample using LiquidCrystal library
#include <LiquidCrystal.h>
// select the pins used on the LCD panel
int rs=12, en=11, d4=5, d5=4, d6=3, d7=2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
// define some values used by the panel and buttons
int lcd_key = 0;
int adc_key_in = 0;
#define btnRIGHT 0
#define btnUP 1
#define btnDOWN 2
#define btnLEFT 3
#define btnSELECT 4
#define btnNONE 5
// Default settings
int thrs = 2; // 1, 2, 3 or 4 out of 0 to 5
int oct = 2; // 1, 2 or 3 out of 1 to 3
int vox = 2; // out of 1 to 8
int bnk = 5; // out of 1 to 16
int prog;
int chn = 1; // out of 1 to 16
// read the buttons
int read_LCD_buttons()
adc_key_in = analogRead(0); // read the value from the sensor
// we add approx 50 to those values and check to see if we are close
if (adc_key_in > 1000) return btnNONE; // We make this the 1st option for speed reasons since it will be the most likely result
// For V1.1 us this threshold
if (adc_key_in < 150) return btnLEFT;
if (adc_key_in < 195) return btnDOWN;
if (adc_key_in < 380) return btnSELECT;
if (adc_key_in < 555) return btnRIGHT;
if (adc_key_in < 790) return btnUP;
return btnNONE; // when all others fail, return this...
lcd.begin(20,4); // start the library
lcd.clear();
lcd.setCursor(0,1);
lcd.print("Message Here"); // print a simple message
delay(5000);
lcd.setCursor(0,0);
lcd.print("Data sent:");
lcd.setCursor(9,1); // move cursor to second line "1" and 9 spaces over
lcd.print(random(40,76)); // display seconds elapsed since power-up
lcd.setCursor(0,2);
lcd.print("Button Pressed:");
lcd.setCursor(11,2); // move to the begining of the second line
lcd_key = read_LCD_buttons(); // read the buttons
switch (lcd_key) // depending on which button was pushed, we perform an action
case btnRIGHT:
if(bnk == 15){bnk=-1;}
bnk = bnk+1;
lcd.print("Btn1 ");
case btnLEFT:
if(oct == 3){oct=0;}
oct = oct+1;
lcd.print("Btn2 ");
case btnUP:
if(thrs == 4){thrs=0;}
thrs = thrs+1;
lcd.print("Btn3 ");
case btnDOWN:
if(chn == 16){chn=0;}
if(chn == 9){chn=10;}
chn = chn+1;
lcd.print("Btn4 ");
case btnSELECT:
if(vox == 8){vox=0;}
vox = vox+1;
lcd.print("Btn2 ");
case btnNONE:
lcd.print("None ");
lcd.setCursor(0,3);
lcd.print("Dflt:");
lcd.setCursor(6,3);
lcd.print("T");
lcd.print(thrs);
lcd.setCursor(9,3);
lcd.print("O");
lcd.print(oct);
lcd.setCursor(12,3);
lcd.print("P");
prog = (8*bnk)+vox;
if(prog > 128){
prog = prog-128;
lcd.print(String(prog)+" ");
lcd.setCursor(17,3);
lcd.print("C");
lcd.print(String(chn)+" ");
