Arduino Zero With Wifi.h
have the new Arduino Zero (Team CC). Whenever I add
#include <WiFi.h>
my code stops executing. I believe the issue may have to do with some code being automatically run in the "header-tree" that is Wifi.h I would like to use this library to get my wifi-shield running.
The following code works:
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 3; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
int count = 0;
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn LED on:
count++;
digitalWrite(ledPin, HIGH);
Serial.println(count);
delay(100);
else {
// turn LED off:
digitalWrite(ledPin, LOW);
However after adding that include Wifi.h the project will compile and run but no code actually gets executed.
Also asked at: http://stackoverflow.com/questions/31257009/arduino-zero-with-wifi-h
^RT
Hi jmppmj,
The problem should be solved now!
An update to WiFi library has been released, please upgrade the library to the version 1.2.5 from library manager.
Hey Cmaglie,
I have updated but as soon as I attach my Arduino Wifi Shield 101, the basic WiFi examples such as ScanNetworks does not seem to work. The problem is the same as before, where no code seems to get executed.
When I go back to the example above, with the WiFi shield 101 attached, no code gets executed.
@jmppmj
The WiFi library is for the old Wifi Shield not for the Wifi 101, so it's normal it doesn't work.
I'm wondering where you have found a Wifi 101 Shield since it's not yet on sale? :o
