Arduino
creating variable voltage source
PWM output and RC low-pass filter
How much voltage?
How much current?
What's the application?
Are you trying to make a variable power supply? If so, does it need to be digitally controlled/programmable, or can you use a manual knob?
I thought johnwasser nailed it. Corresponding level of detail in the answer as the question.
I suspect the OP is not quite so amused as I am though...... :grin:
Regards,
Graham
ghlawrence2000: I suspect the OP is not quite so amused as I am though.
Never mind. We are, and that is more valuable than a "one hit wonder". :D
