Is ARDUINO relevant in the electronics industry , or it is mainly a trtaining tool to new in embedded field ?
Thanks
Elico
Thanks
Elico
I'd say that, since it is mainly a hobby/training platform, it is not directly relevant to the electronics industry.
For example, the IDE lacks professional features like a debugger. Also changes can be made which breaks old code (although professional development environments are also not fully immune to this).
A little of both - it's an amazing training tool, that's for sure (though I think Espruino is better to start with for someone with very little electronics experience - it's a more forgiving language (JS instead of C) but the real value is the live console - great for getting a feel for how electricity works in the context of digital electronics), though you may graduate to arduino quickly - or not, I know some very smart people who do all their embedded work on that - but I'm pretty sure it's all hobbyists)
However, a great many makers aspire to go into production and sell/distribute their creations (I do it, but I don't make much money - it's more a motivation to be practical and sane in my making), and like, they do it, and very frequently use the tools that they know in their products. I know of multiple commercial products programmed in Arduino, at least one of which is still a going concern, deploying thousands of units that, in my semi-professional assessment, probably cost close to $100 to manufacture (he complained about the $40 price tag of the good radio units he was using, the board was gigantic (also, had i been the one to design the hardware, it would have been cheaper and sidestepped multiple problems because I also know the chips very well)
What's really powerful about the Arduino environment (and the several alternate IDEs that use the same cores/libraries, ex, platformIO, which I hear very good things about, makefile builds, etc) is that you can use as much or as little of the Arduino "hand-holding" stuff as you want or need - the code I write now looks very different from the code someone new writes (I'm writing registers directly all over the place, sometimes I just straight up do direct port writes just because I know the ports off the top of my head, but have to pull up a pinout chart to find what the Arduino pin number is, that kind of thing - I'm getting to where I can get the jist of assembly without the reference book, I routinely use assembly listings "Huh, why did changing that make the size go up by 2 bytes, I didn't expect it to - dump the .lst and... "Oooooh! Of course!" or "Oh, the compiler is being kinda stupid"*). Sometimes I use setup and loop... (like, for 95+% of use cases, it's a great structure, and it gives you a very sensible starting point) sometimes I override main() and don't.
On the other hand, lots of schools use Arduino as people's first introduction to programming (and for that, more than anything else, I have mad respect for the arduino team - they made it easy enough that schools can give people's FIRST INTRODUCTION TO PROGRAMMING in EMBEDDED C[++]** - C is NOT a forgiving language by any stretch of imagination - and kids like it and learn from it and it's pretty good).
Another thing I would note is that while no large professional western company would use Arduino, it is much more commonly used by startups, entrepreneurs, and - as far as I can tell - in, say, China, it's a lot more relevant. I think the philosophy that guides companies there is "good enough is" rather than "do it the Right Way, by the book, and your team of tech writers documents it" attitude of western companies (for the record, I'm closer to the "good enough is" attitude - and IMO that's why they are so effective in the market - for the end users, good enough is!)
What I love about Arduino is that:
Footnotes:
** Arduino is technically C++, but unless you're making your own classes/libraries, you're basically writing C.
*** I always write for chips, not boards (contrary to the Arduino paradigm of calling everything a "board", renumbering the pins, and I usually use Hansibull's or my third party hardware packages instead of the standard Arduino ones, even when programming a standard Arduino board. Among other things, these cores let you do PIN_PB3 for example, to refer to pin 3 in port B, as opposed to arduino pin numbers.
**** If I can stop writing essay-length posts like this one!!!
6v6gt:
I have never needed a debugger, and I can count on one hand the number of times I've though "oh, debugging this would be so much easier if I could set breakpoints or singlestep" - just add in a bit of code to record what you need, upload again - it's so fast and painless, you don't need it.
I feel you on the official cores (in particular) breaking stuff foolishly; the cores I mentioned above (mine, and Hans/MCUDude's) IMO take a more professional attitude to supporting families of parts, while keeping the advantages of Arduino. And when I break something, I fix it quickly, goddamnit!
@DrAzzy karma++ for the long dissertation and generally for your contribution to the Arduino eco system.
I see that my short contribution could have been a bit more balanced if I added that the Arduino platform is an excellent learning environment and very usable for projects with huge amounts of community produced libraries etc. available for handling peripherals etc. (All free, but of varying qualities and usually poorly documented).
As for the debugger, you have a point but Serial.print() can't be used in all contexts and here is a sample problem I was dealing with a few months ago:
byte i ;
// do something 8 times
for ( i = 7 ; i >= 0 ; i-- ) {
For a reason which was not obvious so late in the night, it did not behave as expected. A debugger would have highlighted it quite quickly.
Surely the compiler spotted the missing semicolon?
TheMemberFormerlyKnownAsAWOL:
Oops. I'll correct that simple typo here. No that wasn't the issue in the original code.
6v6gt:
BT, D T ![]()
DrAzzy, I assume/hope that was a copy paste. +1
