Arduino101 and TImer ISR
Hello!
I am trying to use a timer on the 101 that will trigger an interrupt every x seconds. I initially tried CurieTimerOne, and noticed that my ISR was only being called once. It requires that I restart the timer. My question is, is there another timer on the 101 that supports an ISR without needing to be restarted?
Thanks!
I'm going to assume that your code is wrong, until you prove otherwise. You can start but POSTING YOUR CODE like you were supposed to to start with.
