Arduino_Debug.exe
Agradecería me indique donde obtengo información sobre este software provisto con la IDE 1.6.5
Gracias
Welcome to the forum,
please use English on the international part of the forum,
Think you are looking for - https://www.arduino.cc/en/Main/ReleaseNotes
Please, I need some information about Arduino_Debug.exe. This software comes with Arduino IDE 1.6.5. Thanks
If you run it through the command line it'll give you debug information for the IDE it opens. Apart from the debugging info it is just a build of the same code used to create arduino.exe
IRGAM: Please, I need some information about Arduino_Debug.exe. This software comes with Arduino IDE 1.6.5. Thanks
Some people have different problems starting Arduino.exe, such as "long start time" or "serial port not found" or "no IDE window visible" or something else.
The program Arduino_Debug.exe is a diagnostic software which may help to find out details about problems that may occur during starting the IDE. If your IDE starts without any problem, you never will need an additional start diagnostic from Arduino_Debug.exe
