Arduino_nano & ESP8266 Problem
Hi ,
I have installed my ESP8266 With my Arduino nano , I fixed my Serial Debuggin (Tx1,RX0) ( default )
and for my ESP is pin (10,11) , my baudrate ESP ( 9600 ) and for Serial Dbg ( 9600 ) .
i have all installed for tcp communication ( Wif acces ....).
my Esp is client of my server ( phone with TCP terminal application ) i can send all trame without error (
ESP to phone ) but from Phone to ESP i have a problem some time i recived the trame some time no
Can you help me what kind of problem it can be .
I doubt that a phone with a terminal application acts as a server. But OK.
[code]Can you please post your code using code tags like this line[/code] so the result looks like
I think there is a little language problem; please explain what a 'trame' is? Do you mean frame? If so, what is the data?
 #include <SoftwareSerial.h>
    const int Led_V = 13;
    const int Led_R = 12;
    const int Led_V_Tcp = 9;
    const int Led_R_Tcp = 8;
    const int Led_T = 6;
    const int D_M1 = 7;
    int Def_M1=0;
    String C;
    //int clin=0;
   #define SSID "HUAWEI_ALE-L21_D2E0"
   #define PASS "12345678"
   #define DST_IP "192.168.43.1" //baidu.com
   SoftwareSerial ESP_Serial(10, 11); // RX, TX
   {terminator : 'A';
    pinMode(Led_T, OUTPUT);
    pinMode(D_M1, INPUT);
    pinMode(Led_V, OUTPUT);
   pinMode(Led_R, OUTPUT);
   pinMode(Led_V_Tcp, OUTPUT);
   pinMode(Led_R_Tcp, OUTPUT);
     ESP_Serial.begin(9600);
    // ESP_Serial.setTimeout(1000);
     Serial.begin(9600); //can't be faster than 19200 for softserial
     Serial.println("ESP8266 Demo");
     //test if the module is ready
    ESP_Serial.println("AT+RST");
     delay(1000);/*
     if(ESP_Serial.find("Reday"))
       Serial.println("Module is ready");
       Serial.println("Module have no response.");
       while(1);
     //set the single connection mode
     ESP_Serial.println("AT+CIPMUX=0");
   {Def_M1 = digitalRead(D_M1);
     while(ESP_Serial.available())
 C = ESP_Serial.readStringUntil('A');
       if(ESP_Serial.find("IPD"))
    delay(200);
    Serial.println(C);
    ESP_Serial.println("Reçu");
    if (C[3]=='1')
    digitalWrite(Led_T, HIGH);
    else if (C[3]=='0')
     digitalWrite(Led_T,LOW);
   //    recoitDuESP8266(200);
    connectWiFi1();
     delay(200);
     String cmd = " ";
    /* String cmd = "AT+CIPSTART=\"TCP\",\"";
     cmd += DST_IP;
     cmd += "\",8080";
     ESP_Serial.println(cmd);
     if(ESP_Serial.find("Error")) return;*/
     if (Def_M1 == HIGH)
     cmd = "1"; else cmd ="0";
     ESP_Serial.print("AT+CIPSEND=");
     ESP_Serial.println(cmd.length());
     if(ESP_Serial.find(">"))
    //   Serial.print(">");
           digitalWrite(Led_V_Tcp, HIGH);
         digitalWrite(Led_R_Tcp, LOW);
       }else
         ESP_Serial.println("AT+CIPCLOSE");
         digitalWrite(Led_V_Tcp, LOW);
         digitalWrite(Led_R_Tcp, HIGH);
      //   Serial.println("connect timeout");
     cmd += DST_IP;
     cmd += "\",8080";
     //Serial.println(cmd);
         return;
       ESP_Serial.print(cmd);
     /*  C = ESP_Serial.readStringUntil('A');
       Serial.println(C);
        //Serial.find("+IPD");
       while (ESP_Serial.available())
         char c = ESP_Serial.read();
         Serial.write(c);
         if(c=='\r') Serial.print('\n');
       Serial.println("====");
     boolean connectWiFi()
       ESP_Serial.println("AT+CWMODE=1");
       String cmd="AT+CWJAP=\"";
       cmd+=SSID;
       cmd+="\",\"";
       cmd+=PASS;
       cmd+="\"";
       delay(2000);
       if(ESP_Serial.find("CONNECTED"))
       {digitalWrite(Led_V, HIGH);
         digitalWrite(Led_R, LOW);
         Serial.println("OK, Connected to WiFi.");
         return true;
         }else
           Serial.println("Can not connect to the WiFi.");
         digitalWrite(Led_R, HIGH);
         digitalWrite(Led_V, LOW);
           return false;
        boolean connectWiFi1()
       ESP_Serial.println("AT+CWJAP?");
       if(ESP_Serial.find("No"))
       {digitalWrite(Led_V, LOW);
         //Serial.println("Can not connect to the WiFi.");
         return true;
         }else
        //   Serial.println("Connect the WiFi. OK");
           return false;
       void recoitDuESP8266(const int timeout)
  String reponse = "";
  long int time = millis();
  while( (time+timeout) > millis())
      reponse+=c;
  Serial.println(reponse);
Hou can help me plz !
