Arduinoble analog data send
I am trying to read analog data through BLE communication with two Nano 33 BLE units.
My central code is:
<# include <ArduinoBLE.h>
BLEService batteryService("1101");
BLEUnsignedCharCharacteristic batteryLevelChar("1101", BLERead | BLEWrite);
  while(!Serial);
  pinMode(LED_BUILTIN, OUTPUT);
  if(!BLE.begin()) {
    Serial.println("Starting BLE Failed!");
    while(1);
  BLE.setLocalName("BatteryMonitor");
  BLE.setAdvertisedService(batteryService);
  batteryService.addCharacteristic(batteryLevelChar);
  BLE.addService(batteryService);
  BLE.advertise();
  Serial.println("Bluetooth Device Active, Waiting for Connections...");
  BLEDevice central = BLE.central();
  if(central) {
    Serial.print("Connected to Central: ");
    Serial.println(central.address());
    digitalWrite(LED_BUILTIN, HIGH);
    while(central.connected()) {
      int battery = analogRead(A0);
      int batteryLevel = map(battery, 0, 1023, 0, 100);
      Serial.print("Battery Level % is now : ");
      Serial.println(batteryLevel);
      batteryLevelChar.writeValue(batteryLevel);
      delay(200);
  digitalWrite(LED_BUILTIN, LOW);
  Serial.print("Disconnected from Central: ");
My peripheral code is:
#include <ArduinoBLE.h>
  while (!Serial);
  BLE.begin();
  Serial.println("BLE Central - BatteryMonitor");
  BLE.scanForUuid("1101");
  BLEDevice peripheral = BLE.available();
  if (peripheral) {
    if (peripheral.localName() != "BatteryMonitor") {
      return;
    BLE.stopScan();
    controlLed(peripheral);
void controlLed(BLEDevice peripheral) {
  Serial.println("Connecting...");
  if (peripheral.connect()) {
    Serial.println("Connected");
    Serial.println("Failed to connect!");
    return;
  Serial.println("Discovering attributes ...");
  if (peripheral.discoverAttributes()) {
    Serial.println("Attributes discovered");
    Serial.println("Attribute discovery failed!");
    peripheral.disconnect();
    return;
  BLECharacteristic ledCharacteristic = peripheral.characteristic("1101");
  if (!ledCharacteristic) {
    Serial.println("Peripheral does not have LED characteristic!");
    return;
  } else if (!ledCharacteristic.canWrite()) {
    Serial.println("Peripheral does not have a writable LED characteristic!");
    return;
  while (peripheral.connected()) {
    char v = ledCharacteristic.value();
    Serial.println(v);
    Serial.println("LED on");
    delay(200);
The error in the peripheral code is:
Scan_2:61:37: error: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'char' [-fpermissive]
exit status 1
The error cannot be resolved.
Please fix the error and tell me if there is anything wrong in the code other than the error.
Please remember to use code tags when posting code
Sorry. I didn't know the code tags.
I tried changing it to const char*v =, but it doesn't work.
Sorry, it should've been
const uint8_t*
Please don't ever post those words again.
I tried changing it to const uint8_t*
error code:
error: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'long long unsigned int' [-fpermissive]
 Serial.println(v);
exit status 1
no matching function for call to 'println(const uint8_t*&)'
So, cast it to char* for the print.
What do you expect to see?
The value input to the A0 pin is 0~100.
I want to check this value as it is through BLE communication.
However, other modules cannot read this value.
Your central code has defined a BLE characteristic as unsigned char:
Your peripheral code is expecting a BLE characteristic which is defined as char:
Suggest changing the ledCharacteristic type as BLEUnsignedCharCharacteristic.
