A while ago (last November), I was experimenting with ArduinoBLE to see if I could get it to work on a Teensy 4.x (or 3.6) using the USBHost and BT dongle, and I got it working. At the time I was trying to get it to work with XBox One controllers as well as a BLE mouse (Microsoft Surface Mouse) and had some success. At the time I also tested on Nano 33 ble...
So yesterday I wondered about running the same stuff on the UNO R4 Wifi, so I rebased my fork/branch to current stuff, then merged in the changes from the PR for UNO R4 support.
Also ran with my updated Serial.h/cpp files.
In my Fork/branch, I updated the peripheral explorer sketch to be able to build it to look for one of these two devices.
Looks like it is at least limping along.
Found c8:3f:26:b3:ac:16 'Xbox Wireless Controller' 1812
Connecting ...
Connected
Discovering attributes ...
Attributes discovered
Device name: Xbox Wireless Controll
Appearance: 0x0
Service 1800 //Generic Access service
Characteristic 2a00, properties 0x2, value 0x58626F7820576972656C65737320436F6E74726F6C6C //Device Name
Descriptor 2803, value 0x020300002A //Characteristic
Descriptor 00002a00-0000-0000-0000-000000000000, value 0x58626F7820576972656C65737320436F6E74726F6C6C
Characteristic 2a01, properties 0x2, value 0xC403 //Appearance
Descriptor 2803, value 0x020500012A //Characteristic
Descriptor 00002a01-0000-0000-0000-000000000000, value 0xC403
Characteristic 2a04, properties 0x2, value 0x0A01900100002C01 //Peripheral Preferred Connection Parameters
Descriptor 2803, value 0x020700042A //Characteristic
Descriptor 00002a04-0000-0000-0000-000000000000, value 0x0A01900100002C01
Service 1801 //Generic Attribute service
Service 180a //Device Information service
Characteristic 2a29, properties 0x2, value 0x4D6963726F736F6674 //Manufacturer Name String
Descriptor 2803, value 0x020B00292A //Characteristic
Descriptor 00002a29-0000-0000-0000-000000000000, value 0x4D6963726F736F6674
Characteristic 2a50, properties 0x2, value 0x025E04200B1505 //PnP ID
Descriptor 2803, value 0x020D00502A //Characteristic
Descriptor 00002a50-0000-0000-0000-000000000000, value 0x025E04200B1505
Characteristic 2a26, properties 0x2, value 0x352E31352E333136382E30 //Firmware Revision String
Descriptor 2803, value 0x020F00262A //Characteristic
Descriptor 00002a26-0000-0000-0000-000000000000, value 0x352E31352E333136382E30
Characteristic 2a25, properties 0x2, value 0x3033363030303332393035363234 //Serial Number String
Descriptor 2803, value 0x021100252A //Characteristic
Descriptor 00002a25-0000-0000-0000-000000000000, value 0x3033363030303332393035363234
Service 180f //Battery service
Characteristic 2a19, properties 0x12, value 0x32 //Battery Level
Descriptor 2803, value 0x121400192A //Characteristic
Descriptor 00002a19-0000-0000-0000-000000000000, value 0x32
Descriptor 2902, value 0x0000 //Client Characteristic Configuration
Service 1812 //Human Interface Device service
Characteristic 2a4a, properties 0x2 //HID Information
Descriptor 2803, value 0x0218004A2A //Characteristic
Descriptor 00002a4a-0000-0000-0000-000000000000, value 0x
Characteristic 2a4c, properties 0x4 //HID Control Point
Descriptor 2803, value 0x041A004C2A //Characteristic
Descriptor 00002a4c-0000-0000-0000-000000000000, value 0x
Characteristic 2a4b, properties 0x2 //Report Map
Descriptor 2803, value 0x021C004B2A //Characteristic
Descriptor 00002a4b-0000-0000-0000-000000000000, value 0x
Characteristic 2a4d, properties 0x12 //Report
Descriptor 2803, value 0x121E004D2A //Characteristic
Descriptor 00002a4d-0000-0000-0000-000000000000, value 0x
Descriptor 2908, value 0x0101 //Report Reference
Characteristic 2a4d, properties 0xE //Report
Descriptor 2803, value 0x0E22004D2A //Characteristic
Descriptor 2908, value 0x0302 //Report Reference
Service 00000001-5f60-4c4f-9c83-a7953298d40d
Characteristic 00000002-5f60-4c4f-9c83-a7953298d40d, properties 0x2
Descriptor 2803, value 0x0226000DD4983295A7839C4F4C605F02000000 //Characteristic
Descriptor 00000002-5f60-4c4f-9c83-a7953298d40d, value 0x
Characteristic 00000003-5f60-4c4f-9c83-a7953298d40d, properties 0x2
Descriptor 2803, value 0x0228000DD4983295A7839C4F4C605F03000000 //Characteristic
Descriptor 00000003-5f60-4c4f-9c83-a7953298d40d, value 0x
Characteristic 00000004-5f60-4c4f-9c83-a7953298d40d, properties 0x8
Descriptor 2803, value 0x082A000DD4983295A7839C4F4C605F04000000 //Characteristic
Descriptor 00000004-5f60-4c4f-9c83-a7953298d40d, value 0x
Disconnecting ...
Disconnected
Need to review my notes from then including a couple of issues:
XBox One controller - current firmware (BLE) - (peripheral.discoverAttributes fails · Issue #276 · arduino-libraries/ArduinoBLE (github.com)
Lots of Compiler Warnings - At least if I build for a Teensy 4.1 or Micromod · Issue #274 · arduino-libraries/ArduinoBLE (github.com)
Still does have lots of compiler warnings! - Wish someone would go through and resolve them.
I looked at some of them back then and patched a few of them in my fork/branch, some of which are bugs, like: src\utility\L2CAPSignaling.cpp changed:
for(int i; i<6; i++) peerAddress[5-i] = identityAddress->address[i];
to:
for(int i=0; i<6; i++) peerAddress[5-i] = identityAddress->address[i];
Not sure how far I will take this, but my updates are up in the fork/branch:
KurtE/ArduinoBLE at uno_r4_wifi_teensy (github.com)
Back to playing
