ArduinoBLE - char.writeValue(buf, sizeof(buf) failing
Hi guys,
the char.writeValue() function frustrates me a bit.
Anyone having experience how to fix it? My code compiles and everything works fine but the IMU9DofPackage characteristic is never updated and also the writeValue() returns 0;
buf[45] = {0}
setup(){}
  while(bleIsConntected())
    if(buttonIsPressed()) {
      enableImu = true;
      Serial.println("IMU turned on");
    while(enableImu) {
      ICMupdate(&imuData);
      //Serial.println(imuData.aZ);
        // Encode the data using protobuf library
      pb_ostream_t stream = pb_ostream_from_buffer(buf, sizeof(buf));
      bool encode_status = pb_encode(&stream, ImuData_fields, &imuData);
      if (!encode_status)
        Serial.println("Failed to encode");
        return;
      if(!IMU9DofPackage.writeValue(buf, sizeof(buf))){
        Serial.println("Failed to update Characteristic!");
        enableImu = false;
        Serial.println("IMU turned off");
my BLE lib:
//.h
#ifndef EW_BLE_H
#define EW_BLE_H
#include <ArduinoBLE.h>
//extern BLEDevice central;
extern BLEService eWService;
extern BLECharacteristic IMU9DofPackage;
extern BLECharacteristic TotalInGram;
extern BLECharacteristic ButtonPress;
void BLEinit(const char* ID, int bufferSize, int valueSize = sizeof(uint16_t), int valueSizeButton = sizeof(uint16_t));
bool bleWaitForConnection();
bool bleIsConntected();
void updateArrCharacteristic(BLECharacteristic characteristic, const uint8_t arr[], int lengthOfArray);
void updateUint16_tCharacteristic(BLECharacteristic characteristic, const uint16_t value);
#endif
Please post complete code that compiles without errors.
I found the solution.
For some reason the BLECharacteristic definition has to be global inside the .ino. I do not quite understand why it would be different than global in my header file. Anyway that solved my problem. I could leave all the other definitions/functions and settings in my BLE.cpp/.h
So overall, be careful with exporting the ArduinoBLE functionalities in other files!
