I get a warning and a lot error messages:
Arduino: 1.8.15 (Windows 10), Board: "Nicla Sense ME"
WARNING: library ArduinoBLE claims to run on samd, megaavr, mbed architecture(s) and may be incompatible with your current board which runs on mbed_nicla architecture(s).
Where can I find the right BLE library?
arm-none-eabi-g++: error: sketch\sketch_nov09b.ino.cpp: No such file or directory
arm-none-eabi-g++: warning: '-x c++' after last input file has no effect
arm-none-eabi-g++: fatal error: no input files
compilation terminated.
Multiple libraries were found for "ArduinoBLE.h"
Used: D:\ArduinoSketches\libraries\ArduinoBLE
Not used: D:\ArduinoSketches\libraries\arduino_933146
exit status 1
Error compiling for board Nicla Sense ME.
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp:45:13: error: 'vendor' in namespace 'ble' does not name a type
extern ble::vendor::cordio::CordioHCIDriver& ble_cordio_get_hci_driver();
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp: In static member function 'static ble::CordioHCIDriver& ble::vendor::cordio::CordioHCIHook::getDriver()':
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp:52:22: error: 'ble_cordio_get_hci_driver' was not declared in this scope
return ble_cordio_get_hci_driver();
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp: In static member function 'static ble::CordioHCITransportDriver& ble::vendor::cordio::CordioHCIHook::getTransportDriver()':
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp:56:34: error: 'ble::CordioHCITransportDriver& ble::CordioHCIDriver::_transport_driver' is private within this context
return getDriver()._transport_driver;
In file included from D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp:23:0:
C:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nicla\2.9.9\cores\arduino/mbed/connectivity/FEATURE_BLE/include/ble/driver/CordioHCIDriver.h:230:31: note: declared private here
CordioHCITransportDriver& _transport_driver;
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp: In static member function 'static void ble::vendor::cordio::CordioHCIHook::setDataReceivedHandler(void ()(uint8_t, uint8_t))':
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp:60:36: error: 'static void ble::CordioHCITransportDriver::set_data_received_handler(ble::CordioHCITransportDriver::data_received_handler_t)' is private within this context
getTransportDriver().set_data_received_handler(handler);
In file included from D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp:22:0:
C:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nicla\2.9.9\cores\arduino/mbed/connectivity/FEATURE_BLE/include/ble/driver/CordioHCITransportDriver.h:77:17: note: declared private here
static void set_data_received_handler(data_received_handler_t handler);
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp:60:69: error: 'static void ble::CordioHCITransportDriver::set_data_received_handler(ble::CordioHCITransportDriver::data_received_handler_t)' is private within this context
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp: At global scope:
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp:73:36: error: variable or field 'init_wsf' declared void
void init_wsf(ble::vendor::cordio::buf_pool_desc_t& buf_pool_desc) {
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp:73:36: error: 'buf_pool_desc_t' is not a member of 'ble::vendor::cordio'
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp:73:36: note: suggested alternative:
C:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nicla\2.9.9\cores\arduino/mbed/connectivity/FEATURE_BLE/include/ble/driver/CordioHCIDriver.h:36:8: note: 'ble::buf_pool_desc_t'
struct buf_pool_desc_t {
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp:73:53: error: 'buf_pool_desc' was not declared in this scope
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp:73:53: note: suggested alternative: 'os_pool_def'
os_pool_def
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp: In member function 'virtual int HCICordioTransportClass::begin()':
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp:182:24: error: 'buf_pool_desc_t' is not a member of 'ble::vendor::cordio'
ble::vendor::cordio::buf_pool_desc_t bufPoolDesc = CordioHCIHook::getDriver().get_buffer_pool_description();
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp:182:24: note: suggested alternative:
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp:183:12: error: 'bufPoolDesc' was not declared in this scope
init_wsf(bufPoolDesc);
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp:183:12: note: suggested alternative: 'osPoolDef'
osPoolDef
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp:183:3: error: 'init_wsf' was not declared in this scope
D:\ArduinoSketches\libraries\ArduinoBLE\src\utility\HCICordioTransport.cpp:183:3: note: suggested alternative: 'wait_ns'
wait_ns
exit status 1
