Hello everyone,
I am currently working on a project using an Arduino equipped with an MLX90640 sensor to transmit temperature images via Bluetooth Low Energy (BLE). When I use only the MLX90640 library from Adafruit, the program functions correctly and displays the temperature image as expected. However, when I include the ArduinoBLE library, the sensor operates for just 3 to 5 minutes before it fails.
Additionally, I've noticed that the dynamic memory usage spikes to 70% when both libraries are included.
Best regards,
Youssef
Here's the code that i'm using :
#include <Adafruit_MLX90640.h>
#include <ArduinoBLE.h>
Adafruit_MLX90640 mlx;
float frame[32*24]; // buffer for full frame of temperatures
uint8_t frame_ble[32*24];
// Définir les UUIDs des services et caractéristiques
const char * deviceServiceUuid = "1523";
const char * deviceServiceRequestCharacteristicUuid = "1526";
const char * deviceServiceResponseCharacteristicUuid = "1527";
BLEService ArduinoMLXService(deviceServiceUuid);
BLECharacteristic ArduinoMLXRequestCharacteristic(deviceServiceRequestCharacteristicUuid, BLEWrite, 4);
BLECharacteristic ArduinoMLXResponseCharacteristic(deviceServiceResponseCharacteristicUuid, BLENotify, 768);
while (!Serial) delay(10);
delay(100);
Serial.println("Adafruit MLX90640 Simple Test");
if (! mlx.begin(MLX90640_I2CADDR_DEFAULT, &Wire)) {
Serial.println("MLX90640 not found!");
while (1) delay(10);
Serial.println("Found Adafruit MLX90640");
Serial.print("Serial number: ");
Serial.print(mlx.serialNumber[0], HEX);
Serial.print(mlx.serialNumber[1], HEX);
Serial.println(mlx.serialNumber[2], HEX);
//mlx.setMode(MLX90640_INTERLEAVED);
mlx.setMode(MLX90640_CHESS);
Serial.print("Current mode: ");
if (mlx.getMode() == MLX90640_CHESS) {
Serial.println("Chess");
Serial.println("Interleave");
mlx.setResolution(MLX90640_ADC_18BIT);
Serial.print("Current resolution: ");
mlx90640_resolution_t res = mlx.getResolution();
switch (res) {
case MLX90640_ADC_16BIT: Serial.println("16 bit"); break;
case MLX90640_ADC_17BIT: Serial.println("17 bit"); break;
case MLX90640_ADC_18BIT: Serial.println("18 bit"); break;
case MLX90640_ADC_19BIT: Serial.println("19 bit"); break;
mlx.setRefreshRate(MLX90640_2_HZ);
Serial.print("Current frame rate: ");
mlx90640_refreshrate_t rate = mlx.getRefreshRate();
switch (rate) {
case MLX90640_0_5_HZ: Serial.println("0.5 Hz"); break;
case MLX90640_1_HZ: Serial.println("1 Hz"); break;
case MLX90640_2_HZ: Serial.println("2 Hz"); break;
case MLX90640_4_HZ: Serial.println("4 Hz"); break;
case MLX90640_8_HZ: Serial.println("8 Hz"); break;
case MLX90640_16_HZ: Serial.println("16 Hz"); break;
case MLX90640_32_HZ: Serial.println("32 Hz"); break;
case MLX90640_64_HZ: Serial.println("64 Hz"); break;
/* Initialiser BLE */
BLE.setDeviceName("ArduinoMLX");
BLE.setLocalName("ArduinoMLX");
if (!BLE.begin()) {
Serial.println(F("- Starting Bluetooth® Low Energy module failed!"));
while (1);
BLE.setAdvertisedService(ArduinoMLXService);
ArduinoMLXService.addCharacteristic(ArduinoMLXRequestCharacteristic);
ArduinoMLXService.addCharacteristic(ArduinoMLXResponseCharacteristic);
BLE.addService(ArduinoMLXService);
ArduinoMLXResponseCharacteristic.writeValue((uint8_t*)"0", 1);
BLE.advertise();
Serial.println(F("Arduino R4 WiFi BLE (Peripheral Device)"));
Serial.println(" ");
BLEDevice central = BLE.central();
Serial.println("- Discovering central device...");
if (central) {
Serial.println("* Connected to central device!");
Serial.print("* Device MAC address: ");
Serial.println(central.address());
while (central.connected()) {
if (mlx.getFrame(frame) != 0) {
Serial.println("Failed");
return;
for (uint8_t h=0; h<24; h++) {
for (uint8_t w=0; w<32; w++) {
// float t = frame[h*32 + w];
frame_ble[h*32 + w] = frame[h*32 + w];
Serial.print(frame_ble[h*32 + w]);
Serial.print(", ");
sendLargeDataOverBLE();
// delay(1000);
Serial.println("* Disconnected to central device!");
void sendLargeDataOverBLE() {
for (int i = 0; i < sizeof(frame_ble); i += 20) {
// Create a buffer for the chunk
uint8_t chunk[20];
int chunkSize = min(20, sizeof(frame_ble) - i);
// Copy the chunk from the large data array
memcpy(chunk, frame_ble + i, chunkSize);
// Send the chunk
ArduinoMLXResponseCharacteristic.writeValue(chunk, chunkSize);
// Small delay to ensure the BLE stack can handle the next packet
delay(10);
Yes my question is why it is failing after 3 or 5 minutes ?
Best Regards
