Hi there,
I recently started a project in which I would like connect unity3d with arduino and read in sensor data via bluetooth. I bought a ArduinoBT as usage sounded relativly simple. Now I have to discover that this board can be a kind of a beast! I was able to connect the board with my pc and could load up a sketch. After example-sketch "Blink" worked fine, I uploaded the "Button" sketch to check the sending of data in the serial port. That as well worked fine at the beginning, but then the problems started.
I couldn`t upload another sketch, even with the special reset-then-directly-upload-timing I was unsuccessful. I was told by the console that that the com port was busy.
I even could not open the serial monitor and have a look at the sent data!
I have the assumption that the board is now sending data over the com port all the time and so is somehow blocking the port.
As I cannot upload anything anymore the possible solution might be to overright the atmel with an external avr-isp-programmer and then only write sketches that do not send data all the time but only if requested to!? Is this correct? Are there any other solutions?
I am still quite a noob in this area and I hope I can find somebody here who knows the board better than me and might share his experience.
Thanks a lot!
Tim
