ArduinoBT problem
hey,
i have an arduinobt and i have made it display rss feeds from processing, it worked very well but i stoped for a while with it and now when i try to pair it with the computer, the computer doesn’t know arduinobt, i’ve try with my bt mobile phone to see if it discovered the arduinobt but it doesn’t, could i have burned out the bt module on the arduinoBT ?
ps: the code in arduinobt board still work… the arduino board itself did not burned out… help me please!
is there a quick way to reset the BT module?
Have u tried pushing the reset button before trying to pair it?
In my case it worked (I had the same problem)
yes, i’ve done that already. I have two arduinoBT boards and some time ago, it happened with the other one but i’ve done what u said and it worked (then i have done a reset in BT module and it worked great) but with this board now it doesn’t work… :’(
And other thing, the BT module is turning brown in some parts, in both bt boards, it’s not shinny as when i bought them, is your still shinny ?
I power them with 3 AA, what makes 4,5V so i don’t think it’s from the power supply (they say max 5.5V)
I saw that arduinoBT gives these problems (searching the forum, some users report the same problem), so a few question:
-is it possible to burn out only the bt module ?
  • can it be a hardware problem in arduinoBT boards? (should the max be 3.3v (because bt module?) and not 5.5v? )
  • Is there any way to reset the BT module? using the USB rx/tx from arduino? how about pin 7?
  • have any of u use the arduinoBT for a long time? more than 24 powered on? the bt module turned less shinny?
Thanks a lot
I’ve not done so, but I would think it probable.
The Arduino has a switching regulator on board which generates 5V for the AVR chip. This feeds into a linear regulator that produces the 3.3V for the BT module. You should be able to measure these voltages with a meter.
I have had mine running for several days at a time without noticing any changes. (Though it could be I’m not looking for them, so haven’t seen them).
I hope this helps a little,
Mike
Thanks for the reply Mike, but i still in the same, this is very strange since the board is not burned out (the code on it still works), only the BT doesn’t seems to work…
Did u powered ur arduinoBT with how many volts? am i making a mistake powering mine with 4,5 volts?
and just one more question, what do i need to make a reset to the arduinoBT board? ou reconfigure the BT module, perphaps it’s something wrong there… can it be done over arduinousb? or do i need that stuff do burn the bootloader again?
Thanks in advance…
Paulo
I use 3 AA cells - like you, 4.5Volts.
The swithcing regulator will bring that up to 5V for the AVR and a linear regulator will drop it to 3.3V for the bluegiga module. Do measure these voltages on your board with a multimeter, if only for peace of mind.
There are a couple of capacitors either side of the linear regulator that will be big enough to put a probe on.
The reset pin of the BT module is connected to pin 7. Waggle that pin in code to do a reset.
There is an article about reprogramming the BT module here:
http://www.arduino.cc/playground/Learning/BTWT11Interface
This has never happened to me, so I’m afraid I can’t help much.
Mike
