ArduinoBT rxtx Java COMMs
I’ve have a simple echo prog. running on the ArduinoBT connecting from WinXP SP2; and it works fine when using the windows hyper-terminal as a client.
From Java using rxtx 2.1.7, however, it works but requires first manually connecting the serial port service in blueSoleil; then is very slow to send/receive;
finally it does not disconnect the serial port service after completion.
I am thinking that since both windows hyper-terminal & the avrdude loader are able to connect/disconnect automatically and are much faster than Java that maybe I am doing something wrong?
As a bluetooth nube - any assistance is appreciated.
Lee
Java Client Code:
public class EchoTest implements SerialPortEventListener, Runnable {
private static final int SPEED_19200 = 115200;
private static CommPortIdentifier portId;
private static SerialPort serialPort;
private static Enumeration portList;
private static String defaultPort = “COM5”;
private OutputStream outputStream = null;
private InputStream inputStream = null;
private PrintWriter pw = null;
public static void main(String args) {
boolean portFound = false;
try {
portId = CommPortIdentifier.getPortIdentifier(defaultPort);
portFound = true;
} catch (NoSuchPortException e1) {
// TODO Auto-generated catch block
e1.printStackTrace();
if (portFound) {
EchoTest st = new EchoTest();
Thread xThread = new Thread(st);
xThread.start();
try {
xThread.join();
st.close();
} catch (InterruptedException e) {
System.exit(0);
public void run() {
try {
setup();
println(“1cha cha cha”);
println(“2cha cha cha”);
println(“3cha cha cha”);
} catch (Throwable e) {
System.out.println(e.getMessage());
e.printStackTrace();
public void println(final String s) {
String s1 = “”;
pw.println(s);
private void close() {
// pw.flush(); // flush causes an exception, but does not seem to be necessary
try {
pw.close();
outputStream.close();
Thread.currentThread().sleep(1000);
inputStream.close();
} catch (Exception e) {
private void setup() {
try {
serialPort = (SerialPort) portId.open(“SimpleReadApp”, 2000);
try {
serialPort.setSerialPortParams(SPEED_19200, SerialPort.DATABITS_8,
SerialPort.STOPBITS_1,
SerialPort.PARITY_NONE);
} catch (UnsupportedCommOperationException e) {
try {
inputStream = serialPort.getInputStream();
} catch (IOException e) {
e.printStackTrace(); }
try {
outputStream = serialPort.getOutputStream();
pw = new PrintWriter(outputStream);
try {
serialPort.addEventListener(this);
} catch (TooManyListenersException e) {
serialPort.notifyOnDataAvailable(true);
public void serialEvent(SerialPortEvent event) {
switch (event.getEventType()) {
case SerialPortEvent.BI:
case SerialPortEvent.OE:
case SerialPortEvent.FE:
case SerialPortEvent.PE:
case SerialPortEvent.CD:
case SerialPortEvent.CTS:
case SerialPortEvent.DSR:
case SerialPortEvent.RI:
case SerialPortEvent.OUTPUT_BUFFER_EMPTY:
case SerialPortEvent.DATA_AVAILABLE:
byte readBuffer = new byte[20];
try {
int numBytes = 0;
StringBuilder sb = new StringBuilder();
while (inputStream.available() > 0) {
numBytes = (byte) inputStream.read(readBuffer);
sb.append(new String(readBuffer, “ASCII”).substring(0, numBytes));
System.out.println("Read: "+sb.toString());
} catch (IOException e) {}
ArduinoBT Code:
byte val;
while (Serial.available()) {
// read the most recent byte (which will be from 0 to 255)
val = Serial.read();
Serial.print(val, BYTE);
Update: I have found two workarounds for the above Java rxtx problem, as follows:
1) Use serproxy as mentioned in another thread: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1206439823/0
2) Also using a JSR-82 J2SE implementation. specifically I tried http://code.google.com/p/bluecove/. If anyone is interested in the latter, I'll post more.
Lee
could you post more about the second one? thanks
