'ArduinoCloud' was not declared in this scope
I keep getting this error when compiling the code that I copied and pasted from this link:
https://create.arduino.cc/projecthub/adriensales/legacy-mailbox-sms-notifier-ec6d4b
HERE IS THE CODE::
#include "arduino_secrets.h"
  Sketch generated by the Arduino IoT Cloud Thing "MAILBOX"
  https://create.arduino.cc/cloud/things/9b41adac-e48d-428e-9ccd-0dddd50c4be5
  Arduino IoT Cloud Properties description
  The following variables are automatically generated and updated when changes are made to the Thing properties
  int deliveries;
  Properties which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
// PIN configuration
const int trigPin = 6;    // Trigger
const int echoPin = 7;    // Echo
// variables
long duration, cm, inches;
int prev_cm = 30;
int curr_cm = 30;
int prev_status = 0;
int curr_status = 0;// out
int zone_radius_cm = 10;
int nb_current_deliveries = 0;// number of times an input has been detected
int nb_previous_deliveries = 0;
int loop_counter = 0;
  // Initialize serial and wait for port to open:
  // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
  delay(1500);
  Serial.println("Booting Mailbox scanner...");
  delay(200);
  // Defined in thingProperties.h
  initProperties();
  setDebugMessageLevel(4);
  ArduinoCloud.printDebugInfo();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
     The following function allows you to obtain more information
     related to the state of network and IoT Cloud connection and errors
     the higher number the more granular information you’ll get.
     The default is 0 (only errors).
     Maximum is 4
 deliveries = 0;
  //Define inputs and outputs
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  // some led pight
  pinMode(LED_BUILTIN, OUTPUT);
  Serial.println("Mailbox scanner booted.");
  ArduinoCloud.update();  //HERE IS THE ERROR
  // Your code here
  if (nb_current_deliveries > nb_previous_deliveries){
  Serial.println("Watching inbox...");
  // The sensor is triggered by a HIGH pulse of 10 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  digitalWrite(trigPin, LOW);
  delayMicroseconds(5);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Read the signal from the sensor: a HIGH pulse whose
  // duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  duration = pulseIn(echoPin, HIGH);
  // Convert the time into a distance
  cm = (duration/2) / 29.1;     // Divide by 29.1 or multiply by 0.0343
  //inches = (duration/2) / 74;   // Divide by 74 or multiply by 0.0135
  prev_cm = curr_cm;
  curr_cm = cm;
  prev_status = curr_status;
  //Serial.print(inches);
  //Serial.print("in, ");
  //Serial.print(cm);
  //Serial.print("cm");
  //Serial.println();
  if (curr_cm < zone_radius_cm){
    // object in the zone
    Serial.println("");
    Serial.println("Object in the zone !");
    // Increase nb. of deliveries
    nb_previous_deliveries = nb_current_deliveries;
    nb_current_deliveries++;
    // update deliveries for cloud counter
    deliveries++;
    //ack = false;
    Serial.println("Acknowledge flag reset to false.");
    notify();
    Serial.println("Sleeping for a while now...");
    delay(3000);
    //prev_status = curr_status;
    curr_status = 1;
  else {
    if(loop_counter == 0){
    Serial.print(".");
    //"Serial.println("No activity in the zone, watching moves...");
    delay(100); // Wait for 100 millisecond(s)
  delay(100);
  loop_counter++;
  loop_counter = loop_counter % 25;
//                        Custom functions
void notify(){
      Serial.println("Notifying...");
      //digitalWrite(LED_BUILTIN, HIGH);
      Serial.print("<");
      Serial.print(nb_current_deliveries);
      Serial.println("> total deliveries.");
      //delay(10000);
      Serial.println("Notified.");
      Serial.println("#################################");
      //digitalWrite(LED_BUILTIN, LOW);
      int i = 0;
      while ( i < 20){
        digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
        delay(200);                       // wait for a second
        digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
        delay(200);
        i++;
and here is the full error message
Arduino: 1.8.15 (Mac OS X), Board: "Arduino MKR1000"
In file included from /Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino:18:0:
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h: In function 'void initProperties()':
thingProperties.h:13:3: error: 'ArduinoCloud' was not declared in this scope
ArduinoCloud.setThingId(THING_ID);
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h:13:3: note: suggested alternative: 'Arduino_h'
Arduino_h
thingProperties.h:14:28: error: 'deliveries' was not declared in this scope
ArduinoCloud.addProperty(deliveries, READ, ON_CHANGE, NULL);
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h:14:28: note: suggested alternative: 'Deliveries'
Deliveries
thingProperties.h:14:40: error: 'READ' was not declared in this scope
thingProperties.h:14:46: error: 'ON_CHANGE' was not declared in this scope
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h:14:46: note: suggested alternative: 'CHANGE'
CHANGE
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h: At global scope:
thingProperties.h:17:1: error: 'ConnectionManager' does not name a type
ConnectionManager *ArduinoIoTPreferredConnection = new WiFiConnectionManager(SSID, PASS);
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino: In function 'void setup()':
MAILBOX_notifier:49:3: error: 'setDebugMessageLevel' was not declared in this scope
MAILBOX_notifier:50:3: error: 'ArduinoCloud' was not declared in this scope
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino:50:3: note: suggested alternative: 'Arduino_h'
Arduino_h
MAILBOX_notifier:53:22: error: 'ArduinoIoTPreferredConnection' was not declared in this scope
MAILBOX_notifier:62:2: error: 'deliveries' was not declared in this scope
deliveries = 0;
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino:62:2: note: suggested alternative: 'Deliveries'
deliveries = 0;
Deliveries
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino: In function 'void loop()':
MAILBOX_notifier:75:3: error: 'ArduinoCloud' was not declared in this scope
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino:75:3: note: suggested alternative: 'Arduino_h'
Arduino_h
MAILBOX_notifier:118:5: error: 'deliveries' was not declared in this scope
deliveries++;
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino:118:5: note: suggested alternative: 'Deliveries'
deliveries++;
Deliveries
exit status 1
option enabled in File -> Preferences.
ANY HELP IS/WOULD BE APPRECIATED
Why do you think this is a bootloader issue?
What's a bootloading issue? I am pretty new to this, so is there any way that you could explain boot loading?
Well, you posted your question in the bootloading section of the forum, so presumably you thought it wasn't a programming question or a project guidance section.
well, yeah, it is a programming question. So I thought that this would be the right category...
I tried what you said, but it didn't work
So, do you think that you could help me
I need help with this code that I got from this online project: https://create.arduino.cc/projecthub/adriensales/legacy-mailbox-sms-notifier-ec6d4b
I just copied and pasted, and now after fixing 1 error, I have about 30.
Here is the main code:
#include "thingproperties.h"
  int deliveries;
// variables
int prev_cm = 30;
int curr_cm = 30;
  delay(1500);
  delay(200);
  initProperties();
     Maximum is 4
 deliveries = 0;
  // some led pight
  // Your code here
  prev_cm = curr_cm;
  curr_cm = cm;
  //Serial.print(cm);
  //Serial.println();
    Serial.println("");
    deliveries++;
    //ack = false;
    notify();
    delay(3000);
    curr_status = 1;
  else {
    Serial.print(".");
  delay(100);
  loop_counter++;
//                        Custom functions
void notify(){
      Serial.print("<");
      //delay(10000);
      int i = 0;
      while ( i < 20){
        delay(200);
        i++;
I need help on line 76. Any help is appreciated. HERE IS THE FULL ERROR MESSAGE
In file included from /Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino:2:0:
thingProperties.h:14:4: error: 'ArduinoCloud' was not declared in this scope
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h:14:4: note: suggested alternative: 'Arduino_h'
Arduino_h
thingProperties.h:15:40: error: 'READ' was not declared in this scope
thingProperties.h:15:46: error: 'ON_CHANGE' was not declared in this scope
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h:15:46: note: suggested alternative: 'CHANGE'
CHANGE
thingProperties.h:19:1: error: 'ConnectionManager' does not name a type
In file included from /Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino:19:0:
thingProperties.h:5:21: error: redefinition of 'const char THING_ID []'
const char THING_ID[] = "97e8b9343-d81e-45d7-84bc-61eafe7cd9b7";
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h:5:12: note: 'const char THING_ID [38]' previously defined here
thingProperties.h:7:17: error: redefinition of 'const char SSID []'
const char SSID[] = "WiFi"; // Network SSID (name)
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h:7:12: note: 'const char SSID [5]' previously defined here
thingProperties.h:8:17: error: redefinition of 'const char PASS []'
const char PASS[] = "C@st1nelu5"; // Network password (use for WPA, or use as key for WEP)
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h:8:12: note: 'const char PASS [11]' previously defined here
thingProperties.h:11:5: error: redefinition of 'int deliveries'
int deliveries;
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h:11:5: note: 'int deliveries' previously declared here
int deliveries;
thingProperties.h:13:6: error: redefinition of 'void initProperties()'
void initProperties(){
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h:13:6: note: 'void initProperties()' previously defined here
Arduino_h
CHANGE
MAILBOX_notifier:50:3: error: 'setDebugMessageLevel' was not declared in this scope
MAILBOX_notifier:51:2: error: 'ArduinoCloud' was not declared in this scope
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino:51:2: note: suggested alternative: 'Arduino_h'
Arduino_h
MAILBOX_notifier:54:21: error: 'ArduinoIoTPreferredConnection' was not declared in this scope
MAILBOX_notifier:76:4: error: 'ArduinoCloud' was not declared in this scope
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino:76:4: note: suggested alternative: 'Arduino_h'
Arduino_h
exit status 1
This project appears to be using an older version of the ArduinoIoTCloud library. Maybe the sketch will compile if you install some older version of the library. It probably won't work but it may compile.
Cross-posts merged. @bullsarethebest please only make one topic for each subject matter.
