I am trying to run the ArduinoCreateAgent-1.2.3-linux-x64.run program on a Raspberry Pi 4 (Ubuntu Desktop). I am not sure if this is possible?
Following the Arduino instructions I downloaded the ArduinoCreateAgent-1.2.3-linux-x64.run program and double clicked the executable. This produces the following zero byte text file: 0S@@�x%@8 (invalid encoding)
I then tried to run the executable as follows:
sudo ./ArduinoCreateAgent-1.2.3-linux-x64.run
[sudo] password for david:
./ArduinoCreateAgent-1.2.3-linux-x64.run: 1: ELF: not found
./ArduinoCreateAgent-1.2.3-linux-x64.run: 5: Syntax error: "(" unexpected
Is the root cause of my problem trying to use the Raspberry pi 4 or is there some configuration step that I am missing. Thanks in advance for your help.
David
