I seen a compile error in the online Create Editor, but then after updating the ArduinoIoTCloud library in the Arduino IDE, I am seeing the same error.
This is not seen with ArduinoIoTCloud 0.5.8
/home/jomoros/Arduino/MKRLED_mar18a/MKRLED_mar18a.ino: In function 'void setup()':
MKRLED_mar18a:53:49: error: cannot convert 'const char*' to 'DebugLevel' for argument '1' to 'void debugMessage(DebugLevel, char*, ...)'
debugMessage("Return From IoT Cloud begin.", 2);
Multiple libraries were found for "WiFi101.h"
Used: /home/jomoros/Arduino/libraries/WiFi101
Not used: /home/jomoros/Arduino/libraries/WiFi101-master
Multiple libraries were found for "Servo.h"
Used: /home/jomoros/Arduino/libraries/Servo
Not used: /home/jomoros/arduino-11232018/libraries/Servo
exit status 1
This is what is see from the online Arduino Editor
/home/builder/opt/arduino-builder/arduino-builder -compile -core-api-version 10611 -hardware /home/builder/opt/arduino-builder/hardware -hardware /home/builder/.arduino15/packages -tools /home/builder/opt/arduino-builder/tools -tools /home/builder/.arduino15/packages -built-in-libraries /home/builder/opt/libraries/latest -logger humantags -fqbn arduino:samd:mkr1000 -build-cache /tmp -build-path /tmp/266547630/build -verbose -prefs runtime.tools.i586-poky-linux-uclibc.path=/home/builder/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0 -prefs runtime.tools.openocd.path=/home/builder/.arduino15/packages/arduino/tools/openocd/0.9.0-arduino6-static -prefs runtime.tools.sketchUploader.path=/home/builder/.arduino15/packages/Intel/tools/sketchUploader/1.6.2+1.0 -prefs runtime.tools.CMSIS.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs runtime.tools.nrf5x-cl-tools.path=/home/builder/.arduino15/packages/arduino/tools/nrf5x-cl-tools/9.3.1 -prefs runtime.tools.arduinoOTA.path=/home/builder/.arduino15/packages/arduino/tools/arduinoOTA/1.2.0 -prefs runtime.tools.arm-none-eabi-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1 -prefs runtime.tools.bossac.path=/home/builder/.arduino15/packages/arduino/tools/bossac/1.7.0 -prefs runtime.tools.arduino101load.path=/home/builder/.arduino15/packages/Intel/tools/arduino101load/2.0.1 -prefs runtime.tools.flashpack.path=/home/builder/.arduino15/packages/Intel/tools/flashpack/2.0.0 -prefs runtime.tools.avr-gcc.path=/home/builder/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs runtime.tools.linuxuploader.path=/home/builder/.arduino15/packages/arduino/tools/linuxuploader/1.5.1 -prefs runtime.tools.arc-elf32.path=/home/builder/.arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1 -prefs runtime.tools.x86-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/x86-linux-gcc/7.2.0 -prefs runtime.tools.dfu-util.path=/home/builder/.arduino15/packages/arduino/tools/dfu-util/0.9.0-arduino1 -prefs runtime.tools.core2-32-poky-linux.path=/home/builder/.arduino15/packages/Intel/tools/core2-32-poky-linux/1.6.2+1.0 -prefs runtime.tools.arm-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-linux-gcc/4.9.3 -prefs runtime.tools.avrdude.path=/home/builder/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8 -prefs runtime.tools.CMSIS-Atmel.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0 -libraries /tmp/266547630/custom -libraries /tmp/266547630/pinned /tmp/266547630/MKRLED_mar18a
Used: /home/builder/opt/libraries/latest/servo_1_1_3
Not used: /home/builder/opt/libraries/latest/rokitsmart_1_0_9
Not used: /home/builder/opt/libraries/latest/printoo_library_1_0_2
Not used: /home/builder/opt/libraries/latest/evive_2_0_2
Using library ethernet_2_0_0 at version 2.0.0 in folder: /home/builder/opt/libraries/latest/ethernet_2_0_0
Using library SPI at version 1.0 in folder: /home/builder/.arduino15/packages/arduino/hardware/samd/1.6.20/libraries/SPI
/tmp/266547630/MKRLED_mar18a/MKRLED_mar18a.ino: In function 'void setup()':
/tmp/266547630/MKRLED_mar18a/MKRLED_mar18a.ino:55:49: error: cannot convert 'const char*' to 'DebugLevel' for argument '1' to 'void debugMessage(DebugLevel, char*, ...)'
exit status 1
