Good day!
I’m trying to burn a Arduino bootloader into blank Atmega8A-PU using Arduino Duemilanove (Atmega328P) as ISP programmer. The target configuration is without external clock.
Here is the wiring: http://arduino.cc/en/uploads/Tutorial/SimpleBreadboardAVR.png
The bootloader comes from here: http://todbot.com/blog/2009/05/26/minimal-arduino-with-atmega8/
(The same as original, just changed for 8Mhz).
Here are settings from boards.txt:
atmega8noxtal.name=ATmega8-noxtal @8MHz
atmega8noxtal.upload.protocol=stk500
atmega8noxtal.upload.maximum_size=7168
atmega8noxtal.upload.speed=38400
atmega8noxtal.bootloader.low_fuses=0xe4
atmega8noxtal.bootloader.high_fuses=0xc4
atmega8noxtal.bootloader.path=atmega8_noxtal
atmega8noxtal.bootloader.file=ATmegaBOOT.hex
atmega8noxtal.bootloader.unlock_bits=0x3F
atmega8noxtal.bootloader.lock_bits=0x0F
atmega8noxtal.build.mcu=atmega8
atmega8noxtal.build.f_cpu=8000000L
atmega8noxtal.build.core=arduino
I’ve enabled detailed messages in Arduino IDE. It seems it first run avrdude to write fuses and lock bits.
I’ve tried to upload avrdude to the latest version as described here: http://letsmakerobots.com/node/21412
Here is an error:
C:\Tools\arduino\hardware/tools/avr/bin/avrdude -CC:\Tools\arduino\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega8 -cstk500v1 -P\\.\COM10 -b19200 -e -Ulock:w:0x3F:m -Uhfuse:w:0xc4:m -Ulfuse:w:0xe4:m
avrdude: Version 5.10, compiled on Jan 19 2010 at 10:45:23
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Tools\arduino\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM10
Using Programmer : stk500v1
Overriding Baud Rate : 19200
[...skip...]
avrdude: Device signature = 0x0000ff
avrdude: Expected signature for ATMEGA8 is 1E 93 07
Double check chip, or use -F to override this check.
Sometimes I get this:
avrdude: Device signature = 0x8133ff
avrdude: Send: Q [51] [20]
or this:
avrdude: Device signature = 0xffffff
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
Is chip brokent\locked? May be I’ve erased the signature in some way (as described here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1248979803)
