ArduinoISP broken in Arduino 1.0
I’ve been using ArduinoISP successfully on an Arduino Uno with Arduino 0022 software for several months. Having upgraded to Arduino 1.0, I find that if I compile and upload ArduinoISP using Arduino 1.0, I cannot program my target hardware (atmega328 running at 8MHz). It gives the same error each time. Here is a transcript of the session:
Binary sketch size: 11662 bytes (of a 32256 byte maximum)
C:\arduino-1.0\hardware/tools/avr/bin/avrdude -CC:\arduino-1.0\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM5 -b19200 -Uflash:w:C:\Users\David\AppData\Local\Temp\build1997400296219766435.tmp\controller.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\arduino-1.0\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM5
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
<cut to stay within max message size allowed by the forum>
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82]   [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv: . [00]
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: Recv: . [1e]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00]   [20]
avrdude: Recv: . [95]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
avrdude: Recv: . [0f]
################################## | 100% 0.12s
avrdude: Device signature = 0x1e950f
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: Send: V [56] . [a0] . [03] . [fc] . [00]   [20]
avrdude: Recv: . [ff]
avrdude: Send: V [56] . [a0] . [03] . [fd] . [00]   [20]
avrdude: Send: V [56] . [a0] . [03] . [fe] . [00]   [20]
avrdude: Send: V [56] . [a0] . [03] . [ff] . [00]   [20]
avrdude: erasing chip
avrdude: Send: V [56] . [ac] . [80] . [00] . [00]   [20]
avrdude: reading input file "C:\Users\David\AppData\Local\Temp\build1997400296219766435.tmp\controller.cpp.hex"
avrdude: writing flash (11662 bytes):
Writing | avrdude: Send: U [55] . [00] . [00]   [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [0c] . [94] b [62] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [05] . [12] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [0c] . [94] . [8a] . [00] . [00] . [00] . [00] . [00] $ [24] . [00] ' [27] . [00] * [2a] . [00] . [00] . [00] . [00] . [00] % [25] . [00] ( [28] . [00] + [2b] . [00] . [00] . [00] . [00] . [00]   [20]
avrdude: Recv:
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x64
avrdude: Send: V [56] @ [40] . [00] . [00] . [0c]   [20]
avrdude: Recv: . [15]
avrdude: stk500_cmd(): programmer is out of sync
If I switch to Arduino-0022 and upload ArduinoISP, then switch back to Arduino 1.0, I can use ArduinoISP to program my target hardware (using the helpful “Upload Using Programmer” feature added in 1.0).
The source code of ArduinoISP is the same for both versions of the software, so I guess there must be a library change in 1.0 that breaks ArduinoISP. Maybe it’s the buffered transmit?
I've had the same problem: http://code.google.com/p/arduino/issues/detail?id=661
It might be because the size of the serial receive buffers changed in Arduino 1.0 (to 64 bytes from 128 in 0022). If I put them back to 128 bytes, it works again. I don't understand why, though, because it seems like should it read the bytes out of the buffer as soon as they arrive.
Thanks mellis, I'll try increasing the serial buffer size. I guess ArduinoISP must be busy doing something else while Avrdude is sending it lots of data? Maybe a lower baud rate would also fix it?
mellis: I've had the same problem: http://code.google.com/p/arduino/issues/detail?id=661
Excellent, I can confirm that it works once buffer is set to 128 (Mega ADK, ArduinoBT probably as well) - argh. Thanks, you solved a huge problem. :)
I have an update for the ArduinoISP sketch that works correctly with Arduino 1.0. If you'd like a copy, send me a Personal Message with your email address.
BTW, the buffer only needs to be 100 :) That's the size of the protocol chunk that is overrunning the 64-byte serial buffer.
