ArduinoISP not compiling
Here is my error:
Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Board: "Arduino/Genuino Uno"
c:\program files\windowsapps\arduinollc.arduinoide_1.8.10.0_x86__mdqgnx93n4wtt\hardware\tools\avr\bin../lib/gcc/avr/4.9.2/../../../../avr/bin/ar.exe: unable to rename 'core\core.a'; reason: File exists
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
How do I fix this?
To be honest you are better off getting rid of the window store version and moving to the regular desktop version.
It also looks like something may be preventing the file being written and that could be one of many things from an over zealous anti virus to a user permissions error or some other cause.
I agree with ballscrewbob.
This sort of error could be caused by your antivirus software. Try TEMPORARILY disabling your antivirus for a single compilation to see if the problem goes away, then turn the antivirus back on. If the problem doesn't occur with the antivirus off you will need to adjust the settings of your antivirus to whitelist the appropriate file, folder, or process so it doesn't interfere with compilation.
Now this dreaded error pops up:
Arduino: 1.8.5 (Windows 10), Board: “Arduino/Genuino Uno”
Sketch uses 13822 bytes (42%) of program storage space. Maximum is 32256 bytes.
Global variables use 687 bytes (33%) of dynamic memory, leaving 1361 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xa4
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
“Show verbose output during compilation”
option enabled in File → Preferences.
That's progress. You've successfully compiled the program but now the upload is failing.
Select the port of your Arduino from the Tools > Port menu. If that menu is grayed out or the port of your Arduino board is not shown then one of the following may be the cause:
  • You may need to install the driver for the USB-serial chip on your Arduino. Determine which chip is used on your Arduino and install the driver.
  • You may be using a charge-only or defective USB cable. Test your cable on another device to confirm that it works for data.
  • Using a USB 3.0 port on your computer may cause problems. Try a USB 2.0 port or use a USB 2.0 hub plugged into your USB 3.0 port.
