ArduinoJson 5 - 6
Scheda Wemos mini
//Includes
#include <YoutubeApi.h>
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include <ArduinoJson.h>          //This Sketch doesn't technically need this, but the library does so it must be installed.
//Outputs
#define MAX7219_Data_IN 2         //D4 of WeMos
#define MAX7219_Chip_Select  0    //D3 of WeMos
#define MAX7219_Clock 4           //D2 of WeMos
int buzzer = 15;                  //D8 of WeMos
//Variabels
byte adr = 0x08;
byte num = 0x00;
int i = 0;
long subs = 0;
String thisString_prev;
//------- Replace the following! ------
char ssid[] = "";              // your network SSID (name)
char password[] = "";                // your network key
#define API_KEY ""
#define CHANNEL_ID ""     // makes up the url of channel
WiFiClientSecure client;
YoutubeApi api(API_KEY, client);
unsigned long api_mtbs = 60000; //mean time between api requests
unsigned long api_lasttime;   //last time api request has been done
void shift(byte send_to_address, byte send_this_data)
  digitalWrite(MAX7219_Chip_Select, LOW);
  shiftOut(MAX7219_Data_IN, MAX7219_Clock, MSBFIRST, send_to_address);
  shiftOut(MAX7219_Data_IN, MAX7219_Clock, MSBFIRST, send_this_data);
  digitalWrite(MAX7219_Chip_Select, HIGH);
  pinMode(buzzer, OUTPUT);
  digitalWrite(buzzer, LOW);
  //Define the pins as outputs and disable CS
  pinMode(MAX7219_Data_IN, OUTPUT);
  pinMode(MAX7219_Chip_Select, OUTPUT);
  pinMode(MAX7219_Clock, OUTPUT);
  delay(200);
  //Setup of the 7seg module
  shift(0x0f, 0x00); //display test register - test mode off
  shift(0x0c, 0x01); //shutdown register - normal operation
  shift(0x0b, 0x07); //scan limit register - display digits 0 - 7
  shift(0x0a, 0x0f); //intensity register - max brightness
  shift(0x09, 0xff); //decode mode register - CodeB decode all digits
  // Set WiFi to station mode and disconnect from an AP if it was Previously
  // connected
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  delay(100);
  // Attempt to connect to Wifi network:
  Serial.print("Connecting Wifi: ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  IPAddress ip = WiFi.localIP();
  Serial.println(ip);
  if (millis() - api_lasttime > api_mtbs)  {
    if(api.getChannelStatistics(CHANNEL_ID))
      unsigned long Count = api.channelStats.subscriberCount;
      String thisString = String(Count, DEC);
      if(thisString != thisString_prev)
        analogWrite(buzzer,200);
        analogWrite(buzzer,LOW);
      thisString_prev = thisString;
      i =  thisString.length();//This variable will go character by cahracter and send the value to the 7 segment display
      if(i==8)
          shift(0x0b, 0x07); //scan limit register - display digits 0 thru 7
          adr=0x01;
        if(i==7)
          shift(0x0b, 0x06); //scan limit register - display digits 0 thru 7
          adr=0x01;
        if(i==6)
          shift(0x0b, 0x05); //scan limit register - display digits 0 thru 7
          adr=0x01;
        if(i==5)
          shift(0x0b, 0x04); //scan limit register - display digits 0 thru 7
          adr=0x01;
        if(i==4)
          shift(0x0b, 0x03); //scan limit register - display digits 0 thru 7
          adr=0x01;
        if(i==3)
          shift(0x0b, 0x02); //scan limit register - display digits 0 thru 7
          adr=0x01;
        if(i==2)
          shift(0x0b, 0x01); //scan limit register - display digits 0 thru 7
          adr=0x01;
        if(i==1)
          shift(0x0b, 0x00); //scan limit register - display digits 0 thru 7
          adr=0x01;
        i=i-1;
      while (i >= 0)
        if(thisString[i] == '0')
        num = 0x00;
        if(thisString[i] == '1')
        num = 0x01;
        if(thisString[i] == '2')
        num = 0x02;
        if(thisString[i] == '3')
        num = 0x03;
        if(thisString[i] == '4')
        num = 0x04;
        if(thisString[i] == '5')
        num = 0x05;
        if(thisString[i] == '6')
        num = 0x06;
        if(thisString[i] == '7')
        num = 0x07;
        if(thisString[i] == '8')
        num = 0x08;
        if(thisString[i] == '9')
        num = 0x09;
        shift(adr, num);
        adr=adr+0x01;
        i=i-1;
    api_lasttime = millis();
Nel compilarlo mi da questo errore: DynamicJsonBuffer is a class from ArduinoJson 5. Please see Redirecting… to learn how to upgrade your program to ArduinoJson version 6 DynamicJsonBuffer jsonBuffer;
il problema lo ho capito ma non so come correggere le righe interessate.
se uso le librerie della versione ArduinoJson 5 il problema si risolve ma io volevo aggiornare il programma con le librerie ArduinoJson 6
