Edit: using a Xiao ESP32-C6 with Arduino code
Hi all, Clovis from FritzenLab blog here. I am trying to use ArduinoJSON in the Arduino IDE 2.3.3 nightly to parse currency conversion JSONs and show in an OLED display. The first one I was able to parse (and it worked beautifully) by removing parts of it is:
[{"code":"USD","codein":"EUR","name":"Dólar Americano/Euro","high":"0.9174","low":"0.9129","varBid":"0.0002","pctChange":"0.02","bid":"0.9142","ask":"0.9144","timestamp":"1728680370","create_date":"2024-10-11 17:59:30"}]
that comes from this URL: https://economia.awesomeapi.com.br/json/USD-EUR/1 . What I had to do is use
payload.replace("[", "");
payload.replace("]", "");
in order to remove the brackets so that ArduinoJSON could do its job. Now the second URL
(https://api.freecurrencyapi.com/v1/latest?apikey=fca_live_VY5LigvrlRZa8DDEjEmC6KKqZXVjn4krRXHLkoA3)
that produces this JSON
{"data":{"AUD":1.4812302414,"BGN":1.7857002284,"BRL":5.6023007216,"CAD":1.3760501974,"CHF":0.8568100864,"CNY":7.06607111,"CZK":23.1031928798,"DKK":6.8207610011,"EUR":0.913750181,"GBP":0.7652001405,"HKD":7.7681411973,"HRK":6.4777808725,"HUF":366.5991296416,"IDR":15560.395268402,"ILS":3.7586104659,"INR":84.0984135739,"ISK":136.2421360606,"JPY":149.12577678,"KRW":1346.7958727075,"MXN":19.2684727479,"MYR":4.2857108042,"NOK":10.693421149,"NZD":1.636070264,"PHP":57.2133870147,"PLN":3.9219305098,"RON":4.545630534,"RUB":95.8006011973,"SEK":10.3671417216,"SGD":1.3037801975,"THB":33.1420633372,"TRY":34.2741747093,"USD":1,"ZAR":17.3821821208}}
Had me trying to remove the parts below, but it will not compile because of the "" inside the string
{"data":
and the final "}" doing
payload.replace("{"data":", "");
payload.replace("}}", "}");
So my question is how to get out of this situation, since these JSON are not the "standard" the ArduinoJSON library is expecting?
Full code is below:
// Inclusão da(s) biblioteca(s)
#include <WiFi.h> // Biblioteca nativa do ESP32
#include <HTTPClient.h> // Biblioteca nativa do ESP32
#include <ArduinoJson.h>
// Configurações da rede WiFi à se conectar
const char* ssid = "";
const char* password = "";
String payload;
HTTPClient http; // o objeto da classe HTTPClient
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET -1
Adafruit_SSD1306 display(OLED_RESET);
#define LOGO16_GLCD_HEIGHT 64
#define LOGO16_GLCD_WIDTH 128
long currenttime;
long oldtime;
// Inicia Serial
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.display();
delay(2000);
// Clear the buffer.
display.clearDisplay();
WiFi.disconnect(); // Desconecta do WiFI se já houver alguma conexão
WiFi.mode(WIFI_STA); // Configura o ESP32 para o modo de conexão WiFi Estação
Serial.println("[SETUP] Tentando conexão com o WiFi...");
WiFi.begin(ssid, password); // Conecta-se à rede
if (WiFi.waitForConnectResult() == WL_CONNECTED) // aguarda até que o módulo se
// conecte ao ponto de acesso
Serial.println("[SETUP] WiFi iniciado com sucesso!");
} else
Serial.println("[SETUP] Houve falha na inicialização do WiFi. Reiniciando ESP.");
ESP.restart();
http.begin("https://api.freecurrencyapi.com/v1/latest?apikey=fca_live_VY5LigvrlRZa8DDEjEmC6KKqZXVjn4krRXHLkoA3"); // configura o URL para fazer requisição no servidor
// entra em um laço de repetição infinito
//while (1);
currenttime= millis();
if(currenttime - oldtime > 30000){
oldtime= millis();
Serial.println("[HTTP] GET...");
int httpCode = http.GET(); // inicia uma conexão e envia um cabeçalho HTTP para o
// URL do servidor configurado
Serial.print("[HTTP] GET... código: ");
Serial.println(httpCode);
if (httpCode == HTTP_CODE_OK) // se o cabeçalho HTTP foi enviado e o cabeçalho de
// resposta do servidor foi tratado, ...
Serial.println("[HTTP] GET... OK! Resposta: ");
payload = http.getString(); // armazena a resposta da requisição
Serial.println(payload); // imprime a resposta da requisição
} else // se não, ...
Serial.print("HTTP GET... Erro. Mensagem de Erro: ");
Serial.println(http.errorToString(httpCode).c_str()); // Imprime a mensagem de erro da requisição
http.end();// Fecha a requisição HTTP
JsonDocument remotedata;
DeserializationError error = deserializeJson(remotedata, (char*) payload.c_str());
double conversion= remotedata["EUR"][0];
Serial.println(conversion, 4);
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(0,0);
display.println("EUR to USD");
display.setCursor(15,10);
display.println("One USD buys ");
display.setCursor(15,20);
display.println(conversion, 4);
display.setCursor(50,20);
display.println(" Euros");
display.display();
