OK this seems a good job for a filter.
Try this code:
- start a new sketch, save it as test.ino
in test.ino:
#include <ArduinoJson.h>
#include "data.h"
// The filter: it contains "true" for each value we want to keep
StaticJsonDocument<200> filter;
StaticJsonDocument<1000> doc;
filter["current-scene"] = true;
filter["scenes"][0]["name"] = true;
filter["scenes"][0]["sources"][0]["locked"] = true;
filter["scenes"][0]["sources"][0]["muted"] = true;
filter["scenes"][0]["sources"][0]["name"] = true;
filter["scenes"][0]["sources"][0]["render"] = true;
deserializeJson(doc, (const __FlashStringHelper*) sampleJSON, DeserializationOption::Filter(filter));
serializeJsonPretty(doc, Serial);
void loop() {}
create a second tab in your sketch, call it data.h
in data.h
// C++ raw string literals cf http://en.cppreference.com/w/cpp/language/string_literal
// USE PROGMEM with Program Space Utilities http://www.nongnu.org/avr-libc/user-manual/group__avr__pgmspace.html
const char sampleJSON[] PROGMEM = R"--8<--8<--({
"current-scene": "Welcome",
"message-id": "11",
"scenes": [
"name": "Parte A",
"sources": [
"alignment": 5,
"cx": 0,
"cy": 0,
"id": 3,
"locked": false,
"muted": false,
"name": "AuInCapStreaming",
"render": true,
"source_cx": 0,
"source_cy": 0,
"type": "coreaudio_input_capture",
"volume": 0.9885531067848206,
"x": 0,
"y": 0
"alignment": 5,
"cx": 840,
"cy": 440,
"id": 1,
"locked": false,
"muted": false,
"name": "Hello Text",
"render": true,
"source_cx": 840,
"source_cy": 440,
"type": "text_ft2_source_v2",
"volume": 1,
"x": 0,
"y": 0
"name": "LOG CAM",
"sources": [
"alignment": 5,
"cx": 0,
"cy": 0,
"id": 2,
"locked": false,
"muted": false,
"render": true,
"source_cx": 0,
"source_cy": 0,
"x": 0,
"y": 0
"alignment": 5,
"cx": 1280,
"cy": 720,
"id": 1,
"locked": false,
"muted": false,
"name": "Son Cam",
"render": true,
"source_cx": 1280,
"source_cy": 720,
"type": "av_capture_input",
"volume": 1,
"x": 0,
"y": 0
"name": "Parte B",
"sources": [
"alignment": 5,
"cx": 0,
"cy": 0,
"id": 2,
"locked": false,
"muted": false,
"render": true,
"source_cx": 0,
"source_cy": 0,
"x": 0,
"y": 0
"status": "ok"
})--8<--8<--";
compile and run on your Arduino. Serial Monitor (@ 115200 bauds) will show
[color=purple]
"scenes": [
"name": "Parte A",
"sources": [
"locked": false,
"muted": false,
"render": true
"locked": false,
"muted": false,
"render": true
"name": "LOG CAM",
"sources": [
"locked": false,
"muted": false,
"render": true
"locked": false,
"muted": false,
"name": "Son Cam",
"render": true
"name": "Parte B",
"sources": [
"locked": false,
"muted": false,
"render": true
[/color]
which is basically this structure:
==> you extracted from your JSON string only the fields of interest and now have that in a json document.
if you receive multiple Scenes and you want to build a merge of those, there is an example in the ArduinoJSON documentation.
does it help?
