arduinoJSON Parsing data garbage
Hi! im trying to sending data from arduino uno r3 to nodemcu using arduinoJSON 6.15.1 but its always failed, the arduino didnt sent the data.
i use this tutorial https://engineeringprojectshub.com/serial-communication-between-nodemcu-and-arduino/ and [Fully Explained]--Multiple Data--Serial Communication between Arduino and NodeMCU (ESP8266) - YouTube but the tutorial using arduinoJSON 5 and then i implemented to arduinoJSON 6. When i try use arduinoJSON 5 i got failed too, so i try to implemented arduinoJSON 6, but again, im failed too :frowning:
the connection is very ok! bcs when i tried to sent single data without arduinoJSON its working nicely, but when using arduinoJSON 6 for send multiple data its always failed.
can u help me?
here’s my arduino code
#include <SoftwareSerial.h>
#include <ArduinoJson.h>
SoftwareSerial s(5,6);
  s.begin(1200);
  const size_t capacity = JSON_OBJECT_SIZE(2);
  DynamicJsonDocument doc(capacity);
  doc["data1"] = 100;
  doc["data2"] = 200;
  serializeJson(doc, s);
  delay(3000);
My nodeMCU code
SoftwareSerial s(D1,D2);
  s.begin(1200);
  while (!Serial) continue;
    const size_t capacity = JSON_OBJECT_SIZE(2) + 20;
    delay(3000);
    deserializeJson(doc, s);
    int data1 = doc["data1"]; // 100
    int data2 = doc["data2"]; // 200
    serializeJson(doc, Serial);
and my result in serial monitor
null
{"data1":100,"data2":2000}
null
100
"data2"
null
2000
{"data1":100,"data2":200}
{"data1":100}
null
{"data1":100}
Is there a reason you’re using JSON? It might be easier if you stored all your info in a struct. You could then send the struct between Arduinos reliably using a packetizing/parsing library such as SerialTransfer.h. The library is installable through the Arduino IDE and includes many examples.
Here are the library’s features:
This library:
  • can be downloaded via the Arduino IDE’s Libraries Manager (search “SerialTransfer.h”)
  • works with “software-serial” libraries
  • is non blocking
  • uses packet delimiters
  • uses consistent overhead byte stuffing
  • uses CRC-8 (Polynomial 0x9B with lookup table)
  • allows the use of dynamically sized packets (packets can have payload lengths anywhere from 1 to 254 bytes)
  • can transfer bytes, ints, floats, and even structs!!
Example TX Arduino Sketch:
#include "SerialTransfer.h"
SerialTransfer myTransfer;
  Serial1.begin(115200);
  myTransfer.begin(Serial1);
  char buff[] = "hi";
  myTransfer.txObj(buff, sizeof(buff));
  myTransfer.sendData(sizeof(buff));
  delay(100);
Example RX Arduino Sketch:
  if(myTransfer.available())
    char buff[40];
    myTransfer.rxObj(buff, sizeof(buff));
    Serial.println("New Data: ");
    Serial.write(buff, sizeof(buff));
  else if(myTransfer.status < 0)
    Serial.print("ERROR: ");
    if(myTransfer.status == -1)
      Serial.println(F("CRC_ERROR"));
    else if(myTransfer.status == -2)
      Serial.println(F("PAYLOAD_ERROR"));
    else if(myTransfer.status == -3)
      Serial.println(F("STOP_BYTE_ERROR"));
For theory behind robust serial communication, check out the tutorials Serial Input Basics and Serial Input Advanced.
Power_Broker:
char buff = “hi”;
delay(100);
#include “SerialTransfer.h”
char buff[40];
For theory behind robust serial communication, check out the tutorials [Serial Input Basics](https://forum.arduino.cc/index.php?topic=396450.0) and [Serial Input Advanced](https://forum.arduino.cc/index.php?topic=662346.0).
i want to send multiple data using arduinoJSON to nodemcu, i will implement that code to my project which have two sensor, and then the data will be send to my nodemcu.
ok, i will try and learn about SerialTransfer.
btw sorry for my english, thank you sir!
i hve tried SerialTransfer, but i got an error when i try send data with variable
Arduino Code (tx)
SoftwareSerial mySerial(2, 3); // RX, TX
int data1 = 1;
int data2 = 2;
  mySerial.begin(9600);
  myTransfer.begin(mySerial);
  myTransfer.txBuff[0] = data1;
  myTransfer.txBuff[1] = data2;
  myTransfer.txBuff[2] = '\n';
  myTransfer.sendData(2);
  delay(100);
my nodemcu code (rx)
SoftwareSerial mySerial(D6, D5); // RX, TX
      Serial.print("Data 1 ");
      Serial.write(myTransfer.rxBuff[0]);
      Serial.print("Data 2 ");
      Serial.write(myTransfer.rxBuff[1]);
