Hey all I have a sketch that takes up 99% of my storage space since I am using a Arduino Nano.
Although everything in my code fits as-is, there seems to be an issue with me sending a json string over Serial as its coming back saying "deserializeJson() failed: NoMemory". I've also already used the ArduinoJson Assistant.
My json string looks like this:
{"hardd": {"warrDays": "1265","temp": "102","hddST": "18TB","hddSU": "4TB","hddPB": "70","fan": "4200","date": "Fri Mar 11TH 2024","time": "10:45pm"}}
Note that the iconImages.h has just code that has images to byte code like this (there are 12 total of these):
const unsigned char hdd [] PROGMEM = {
// 'hdd (1), 24x24px
0x00, 0x00, 0x00, 0x3f, 0xff, 0xfc, 0x5f, 0xff, 0xfa, 0x7f, 0xff, 0xfe, 0x7f, 0x00, 0xfe, 0x7e,
0x7e, 0x7e, 0x79, 0xcf, 0x9e, 0x7b, 0x0f, 0xde, 0x76, 0x7f, 0xee, 0x64, 0xff, 0xe6, 0x6d, 0xe7,
0xf6, 0x69, 0x99, 0xf6, 0x69, 0xbd, 0xf6, 0x6b, 0xbd, 0xf6, 0x6f, 0x99, 0xf6, 0x6f, 0xc3, 0xf6,
0x67, 0xff, 0xe6, 0x77, 0xff, 0xee, 0x73, 0xf3, 0xce, 0x79, 0xc7, 0x9e, 0x1c, 0x0e, 0x3e, 0x0f,
0x00, 0xfe, 0x66, 0x07, 0xfe, 0x70, 0x3f, 0xfe, 0x72, 0x7f, 0xfe, 0x76, 0x0d, 0x5e, 0x70, 0xed,
0x1e, 0x5f, 0xed, 0x5a, 0x3f, 0xef, 0xfc, 0x00, 0x00, 0x00
Here is my code - if anyone has any suggestions on how to go about shrinking the amount of storage space/memory so that it wont error out when I send the json string then that would be great!
My code:
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_EMC2101.h>
#include <ArduinoJson.h>
#include "iconImages.h"
#include <Fonts/FreeSans9pt7b.h>
#include <Fonts/FreeMono9pt7b.h>
#include <Fonts/FreeSerif9pt7b.h>
#define hdd_SCREEN_ADDRESS 0x3C
#define apple_SCREEN_ADDRESS 0x3C
#define dell_SCREEN_ADDRESS 0x3C
#define TCAADDR 0x70
// W H
Adafruit_SSD1306 hdd_display(128, 32, &Wire, -1);
Adafruit_SSD1306 apple_display(128, 32, &Wire, -1);
Adafruit_SSD1306 dell_display(128, 32, &Wire, -1);
Adafruit_EMC2101 emc2101;
char character;
//For timer=========================================
const long Minutes = 1;
const long _Interval = (Minutes * 60 * 1000);
unsigned long previousMillis = 0;
//For HDD Stats=====================================
int i = 0;
const char* hdd_warrDays = "";
const char* hdd_temp = "";
const char* hdd_hddST = "";
const char* hdd_hddSU = "";
const char* hdd_hddPB = "";
const char* hdd_fan = "";
//For Apple Stats===================================
const char* apple_os = "";
const char* apple_hddST = "";
const char* apple_hddSU = "";
const char* apple_hddPB = "";
const char* apple_ip = "";
const char* apple_uptime = "";
//For Dell Stats====================================
const char* dell_os = "";
const char* dell_hddST = "";
const char* dell_hddSU = "";
const char* dell_hddPB = "";
const char* dell_ip = "";
const char* dell_uptime = "";
//For Date & Time ==================================
const char* _date = "";
const char* _time = "";
if (!hdd_display.begin(SSD1306_SWITCHCAPVCC, hdd_SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;)
hdd_display.clearDisplay();
hdd_display.display();
hdd_display.setTextColor(WHITE);
if(!apple_display.begin(SSD1306_SWITCHCAPVCC, apple_SCREEN_ADDRESS)) {
for(;;);
apple_display.clearDisplay();
apple_display.display();
apple_display.setTextColor(WHITE);
if(!dell_display.begin(SSD1306_SWITCHCAPVCC, dell_SCREEN_ADDRESS)) {
for(;;);
dell_display.clearDisplay();
dell_display.display();
dell_display.setTextColor(WHITE);
while (Serial.available()) {
String input_content = Serial.readString();
if (input_content.length() > 2) {
Serial.println(input_content);
readAndParseJson(input_content);
input_content = "";
if (currentMillis - previousMillis >= _Interval) {
Serial.println("previousMillis");
if (i == 0 || i == 1 || i == 2 || i == 3) {
i++;
} else if (i == 4) {
i = 0;
doHDD(i);
//doApple(i);
//doDell(i);
delay(100);
String getSplitValues(String data, char separator, int index) {
int found = 0;
int strIndex[] = { 0, -1 };
int maxIndex = data.length() - 1;
for (int i = 0; i <= maxIndex && found <= index; i++) {
if (data.charAt(i) == separator || i == maxIndex) {
found++;
strIndex[0] = strIndex[1] + 1;
strIndex[1] = (i == maxIndex) ? i + 1 : i;
return found > index ? data.substring(strIndex[0], strIndex[1]) : "";
void scanI2C() {
for (uint8_t t = 0; t < 8; t++) {
Wire.beginTransmission(TCAADDR);
Wire.write(1 << t);
Wire.endTransmission();
Serial.print("TCA Port #");
Serial.println(t);
for (uint8_t addr = 0; addr <= 127; addr++) {
if (addr == TCAADDR) continue;
Wire.beginTransmission(addr);
if (!Wire.endTransmission()) {
Serial.print("Found I2C 0x");
Serial.println(addr, HEX);
void readAndParseJson(String json) {
//https://arduinojson.org/v7/assistant
StaticJsonDocument<512> doc;
DeserializationError error = deserializeJson(doc, json);
json = "";
if (error) {
Serial.print(F("deserializeJson() failed: "));
Serial.println(error.f_str());
return;
if (doc.containsKey("hardd")) {
Serial.println("hdd");
JsonObject hdd = doc[F("hardd")];
hdd_warrDays = hdd[F("warrDays")];
hdd_temp = hdd[F("temp")];
hdd_hddST = hdd[F("hddST")];
hdd_hddSU = hdd[F("hddSU")];
hdd_hddPB = hdd[F("hddPB")];
hdd_fan = hdd[F("fan")];
_date = hdd[F("date")];
_time = hdd[F("time")];
} else if (doc.containsKey("apple")) {
Serial.println("apple");
JsonObject apple = doc[F("apple")];
apple_os = apple[F("OS")];
apple_hddST = apple[F("hddST")];
apple_hddSU = apple[F("hddSU")];
apple_hddPB = apple[F("hddPB")];
apple_ip = apple[F("ip")];
apple_uptime = apple[F("uptime")];
} else if (doc.containsKey("dell")) {
Serial.println("dell");
JsonObject dell = doc[F("dell")];
dell_os = dell[F("OS")];
dell_hddST = dell[F("hddST")];
dell_hddSU = dell[F("hddSU")];
dell_hddPB = dell[F("hddPB")];
dell_ip = dell[F("ip")];
dell_uptime = dell[F("uptime")];
void doHDD(int num) {
hdd_display.drawBitmap(0, 0, hdd, 24, 30, WHITE);
if (num == 0) {
//Show tempature
hdd_display.drawBitmap(25, 0, thermometer, 24, 30, WHITE);
hdd_display.setFont(&FreeSans9pt7b);
hdd_display.setCursor(45, 15);
hdd_display.print(hdd_temp);
//hdd_display.print("100");
hdd_display.setTextSize(1);
hdd_display.setCursor(45, 29);
hdd_display.print("tempature");
hdd_display.drawBitmap(75, 0, degreesf, 24, 30, WHITE);
} else if (num == 1) {
//Show warranty
hdd_display.setFont();
hdd_display.drawBitmap(30, 1, warranty, 24, 30, WHITE);
hdd_display.setCursor(60, 3);
//hdd_display.print(341);
hdd_display.print(hdd_warrDays);
hdd_display.print(" day's");
hdd_display.setCursor(60, 13);
hdd_display.print("left of");
hdd_display.setCursor(60, 23);
hdd_display.print("warranty");
} else if (num == 2) {
//Show Hdd stats
hdd_display.drawBitmap(30, 1, hddSpace, 24, 30, WHITE);
//hdd_display.print("5.6TB free");
hdd_display.print(hdd_hddST);
hdd_display.print(" free");
//hdd_display.print("of 18TB");
hdd_display.print("of ");
hdd_display.print(hdd_hddSU);
//drawProgressbar(60, 25, 60, 7, atoi(hdd_hddPB));
int progress = atoi(hdd_hddPB) > 100 ? 100 : atoi(hdd_hddPB);
progress = progress < 0 ? 0 : progress;
float bar = ((float)(60 - 1) / 100) * progress;
hdd_display.drawRect(60, 25, 60, 7, WHITE);
hdd_display.fillRect(60 + 2, 25 + 2, bar, 7 - 4, WHITE);
} else if (num == 3) {
//Show fan rpms
hdd_display.drawBitmap(30, 1, fanSpeed, 24, 30, WHITE);
hdd_display.print("Fan running");
hdd_display.print("@ ");
//hdd_display.print("4,102");
hdd_display.print(hdd_fan);
hdd_display.print(" rpm");
} else if (num == 4) {
//Show date/time
hdd_display.drawBitmap(30, 1, timeAndDate, 24, 30, WHITE);
//hdd_display.print("10:34pm on");
hdd_display.print(_time);
hdd_display.print(" on ");
//hdd_display.print("Fri Sep");
hdd_display.print(getSplitValues(_date, ' ', 0));
hdd_display.print(" ");
hdd_display.print(getSplitValues(_date, ' ', 1));
//hdd_display.print("22nd 2024");
hdd_display.print(getSplitValues(_date, ' ', 2));
hdd_display.print(getSplitValues(_date, ' ', 3));
void doApple(int num) {
String _apple_tmp[3];
apple_display.drawBitmap(0, 0, apple, 24, 30, WHITE);
if (num == 0) {
//Show OS
apple_display.setFont();
apple_display.drawBitmap(30, 1, runningOS, 24, 30, WHITE);
apple_display.setTextSize(1);
apple_display.setCursor(60, 3);
//apple_display.print("macOS 12.9");
apple_display.print(getSplitValues(apple_os, ' ', 0));
apple_display.setCursor(60, 13);
//apple_display.print("Monterey");
apple_display.print(getSplitValues(apple_os, ' ', 1));
apple_display.setCursor(60, 23);
apple_display.print(getSplitValues(apple_os, ' ', 2));
//Show Hdd stats
apple_display.drawBitmap(30, 1, hddSpace, 24, 30, WHITE);
//apple_display.print("5.6TB free");
apple_display.print(apple_hddST);
apple_display.print(" free");
apple_display.print("of ");
//apple_display.print("of 18TB");
apple_display.print(apple_hddSU);
//drawProgressbar(60, 25, 60, 7, atoi(apple_hddPB));
int progress = atoi(apple_hddPB) > 100 ? 100 : atoi(apple_hddPB);
apple_display.drawRect(60, 25, 60, 7, WHITE);
apple_display.fillRect(60 + 2, 25 + 2, bar, 7 - 4, WHITE);
//Show IP address
apple_display.drawBitmap(30, 1, ethernet, 24, 30, WHITE);
//apple_display.print("192.168.1.123");
apple_display.print("IP Address");
apple_display.print("...");
apple_display.print(getSplitValues(apple_ip, '.', 2));
apple_display.print(".");
apple_display.print(getSplitValues(apple_ip, '.', 3));
//Show uptime
apple_display.drawBitmap(30, 1, uptime, 24, 30, WHITE);
//apple_display.print("35 days 17:14");
apple_display.print("Uptime");
apple_display.print(getSplitValues(apple_uptime, ' ', 0));
apple_display.print(" ");
apple_display.print(getSplitValues(apple_uptime, ' ', 1));
apple_display.print(getSplitValues(apple_uptime, ' ', 2));
//Show date/time
apple_display.drawBitmap(30, 1, timeAndDate, 24, 30, WHITE);
//apple_display.print("10:34pm on");
apple_display.print(_time);
apple_display.print(" on ");
//apple_display.print("Fri Sep");
apple_display.print(getSplitValues(_date, ' ', 0));
apple_display.print(getSplitValues(_date, ' ', 1));
//apple_display.print("22nd 2024");
apple_display.print(getSplitValues(_date, ' ', 2));
apple_display.print(getSplitValues(_date, ' ', 3));
void doDell(int num) {
dell_display.drawBitmap(0, 0, dell, 24, 30, WHITE);
if (num == 0) {
//Show OS
dell_display.setFont();
dell_display.drawBitmap(30, 1, runningOS, 24, 30, WHITE);
dell_display.setTextSize(1);
dell_display.setCursor(60, 3);
//apple_display.print("Windows 11");
dell_display.print(getSplitValues(dell_os, ' ', 0));
dell_display.setCursor(60, 13);
dell_display.print("V. ");
dell_display.print(getSplitValues(dell_os, ' ', 1));
dell_display.print(dell_os);
//Show Hdd stats
dell_display.drawBitmap(30, 1, hddSpace, 24, 30, WHITE);
//dell_display.print("5.6TB free");
dell_display.print(dell_hddST);
dell_display.print(" free");
//dell_display.print("of 18TB");
dell_display.print("of ");
dell_display.print(dell_hddSU);
//drawProgressbar(60, 25, 60, 7, atoi(dell_hddPB));
int progress = atoi(dell_hddPB) > 100 ? 100 : atoi(dell_hddPB);
dell_display.drawRect(60, 25, 60, 7, WHITE);
dell_display.fillRect(60 + 2, 25 + 2, bar, 7 - 4, WHITE);
//Show IP address
dell_display.drawBitmap(30, 1, ethernet, 24, 30, WHITE);
//dell_display.print("192.168.1.123");
dell_display.print("IP Address");
dell_display.print("...");
dell_display.print(getSplitValues(apple_ip, '.', 2));
dell_display.print(".");
dell_display.print(getSplitValues(apple_ip, '.', 3));
//Show uptime
dell_display.drawBitmap(30, 1, uptime, 24, 30, WHITE);
//dell_display.print("35 days 17:14");
dell_display.print("Uptime");
dell_display.print(getSplitValues(apple_uptime, ' ', 0));
dell_display.print(" ");
dell_display.print(getSplitValues(apple_uptime, ' ', 1));
dell_display.setCursor(60, 23);
dell_display.print(getSplitValues(apple_uptime, ' ', 2));
//Show date/time
dell_display.drawBitmap(30, 1, timeAndDate, 24, 30, WHITE);
//dell_display.print("10:34pm on");
dell_display.print(_time);
dell_display.print(" on ");
//dell_display.print("Fri Sep");
dell_display.print(getSplitValues(_date, ' ', 0));
dell_display.print(getSplitValues(_date, ' ', 1));
//dell_display.print("22nd 2024");
dell_display.print(getSplitValues(_date, ' ', 2));
dell_display.print(getSplitValues(_date, ' ', 3));
Would be great if someone could look over the code and suggest areas where I could save some memory so the json works.
