I'm getting data from my Google calendar in JSON format. Most of the time all goes well. But occasionally the deserialization produces erratic results. I tried with the payload as String or as c-string (const char *), but that didn't make any difference. It looks like the deserialize function is missing the terminating curly bracket and then picks up left-overs from a previous run. Which is odd, since I clear the String and the Json Document before I do the http GET().
When I copy/paste the payload string in the Json Assistant everything seems correct.
The problem only occurs when I get a shorter string as payload after getting a longer string (i.e. I first ask the calendar data for the coming 100 days and then again for the coming 20 days).
Here is part of my code:
// Now get the calendar data from the Google calendar
Serial.println("Getting Google Recycle calendar data...");
http.begin(urlString);
http.setFollowRedirects(HTTPC_STRICT_FOLLOW_REDIRECTS); // Google script always redirects to Google calendar API
String payload;
payload.clear();
jsonDoc.clear();
DeserializationError err;
int httpResponseCode = http.GET(); // execute the GET request and wait for the response
if (httpResponseCode > 0) //Check the http result code (https://http.dev/status)
Serial.println("checking response...");
payload = (http.getString());
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
Serial.printf("Length of payload string: %lu\n", payload.length());
Serial.print("Payload as String : ");
Serial.println(payload);
Serial.printf("Length of payload char[]: %lu\n", strlen(payload.c_str()));
Serial.print("Payload as char [] : ");
Serial.println(payload.c_str());
err = deserializeJson(jsonDoc, payload);
if(err)
Serial.print("deserializeJson() failed: ");
Serial.println(err.c_str());
if(jsonDoc["data"].is<JsonArray>())
JsonArray j_dataArr = jsonDoc["data"].as<JsonArray>();
const char * timeString;
const char dateAsString [15] = {'\0'};
uint8_t dateLen = 0;
uint8_t eventIndex = 0;
eventCount = 0;
for(auto event : events)
event.type = "";
for(auto j_item : j_dataArr)
events[eventIndex].type = j_item["TYPE"].as<const char *>(); // event type
timeString = j_item["DATE"].as<const char *>(); // event time
strptime(timeString, "%Y-%m-%dT%H:%M:%S", &events[eventIndex].calschedule);
++eventCount;
if(++eventIndex >= sizeof(events)/sizeof(gCalEvent_t)) // if event table full
break; // stop iteration
eventIndex = 1;
if((event.type == NULL) || strlen(event.type) == 0)
Serial.print("Event #");
Serial.print(eventIndex++);
Serial.print(" - TYPE: ");
Serial.print(event.type);
Serial.print(", Date: ");
Serial.println(&event.calschedule, "%A, %B %d %Y");
else if(jsonDoc["data"].is<const char *>()) // if not an array it must be a c-string
const char * GCdata = jsonDoc["data"].as<const char *>();
Serial.printf("Google Cal data = %s\n", GCdata);
Serial.println("Google Data don't make sense...");
It's not a killer problem, since the normal use case is to request only the calender data for the next day, but I'm puzzled why I'm getting this strange misbehaviour.
Hint: deserialization typically fails (does not report an error) if the lenght of the string is between 200 and 400 characters.
The results look like this:
This one is OK. I requested data for the coming 50 days. The payload contains 663 characters and deserialization produces a correct result. Note: I only keep the first 10 results to conserve memory
16:12:38.588 -> Getting Google Recycle calendar data...
16:12:44.019 -> checking response...
16:12:44.127 -> HTTP Response code: 200
16:12:44.127 -> Length of payload string: 663
16:12:44.127 -> Payload as String : {"status":"success","data":[{"TYPE":"RA","DATE":"2024-04-10T05:00:00.000Z"},{"TYPE":"PMD","DATE":"2024-04-10T05:00:00.000Z"},{"TYPE":"P/K","DATE":"2024-04-17T05:00:00.000Z"},{"TYPE":"GFT","DATE":"2024-04-17T05:00:00.000Z"},{"TYPE":"RA","DATE":"2024-04-24T05:00:00.000Z"},{"TYPE":"PMD","DATE":"2024-04-24T05:00:00.000Z"},{"TYPE":"GLAS","DATE":"2024-05-03T05:00:00.000Z"},{"TYPE":"GFT","DATE":"2024-05-03T05:00:00.000Z"},{"TYPE":"RA","DATE":"2024-05-08T05:00:00.000Z"},{"TYPE":"PMD","DATE":"2024-05-08T05:00:00.000Z"},{"TYPE":"GFT","DATE":"2024-05-15T05:00:00.000Z"},{"TYPE":"RA","DATE":"2024-05-22T05:00:00.000Z"},{"TYPE":"PMD","DATE":"2024-05-22T05:00:00.000Z"}]}
16:12:44.128 -> Length of payload char[]: 663
16:12:44.128 -> Payload as char [] : {"status":"success","data":[{"TYPE":"RA","DATE":"2024-04-10T05:00:00.000Z"},{"TYPE":"PMD","DATE":"2024-04-10T05:00:00.000Z"},{"TYPE":"P/K","DATE":"2024-04-17T05:00:00.000Z"},{"TYPE":"GFT","DATE":"2024-04-17T05:00:00.000Z"},{"TYPE":"RA","DATE":"2024-04-24T05:00:00.000Z"},{"TYPE":"PMD","DATE":"2024-04-24T05:00:00.000Z"},{"TYPE":"GLAS","DATE":"2024-05-03T05:00:00.000Z"},{"TYPE":"GFT","DATE":"2024-05-03T05:00:00.000Z"},{"TYPE":"RA","DATE":"2024-05-08T05:00:00.000Z"},{"TYPE":"PMD","DATE":"2024-05-08T05:00:00.000Z"},{"TYPE":"GFT","DATE":"2024-05-15T05:00:00.000Z"},{"TYPE":"RA","DATE":"2024-05-22T05:00:00.000Z"},{"TYPE":"PMD","DATE":"2024-05-22T05:00:00.000Z"}]}
16:12:44.179 -> Event #1 - TYPE: RA, Date: Wednesday, April 10 2024
16:12:44.179 -> Event #2 - TYPE: PMD, Date: Wednesday, April 10 2024
16:12:44.179 -> Event #3 - TYPE: P/K, Date: Wednesday, April 17 2024
16:12:44.210 -> Event #4 - TYPE: GFT, Date: Wednesday, April 17 2024
16:12:44.210 -> Event #5 - TYPE: RA, Date: Wednesday, April 24 2024
16:12:44.210 -> Event #6 - TYPE: PMD, Date: Wednesday, April 24 2024
16:12:44.210 -> Event #7 - TYPE: GLAS, Date: Friday, May 03 2024
16:12:44.210 -> Event #8 - TYPE: GFT, Date: Friday, May 03 2024
16:12:44.210 -> Event #9 - TYPE: RA, Date: Wednesday, May 08 2024
16:12:44.210 -> Event #10 - TYPE: PMD, Date: Wednesday, May 08 2024
Next, I did a request for the coming 20 days...
16:12:50.179 -> Getting input...
16:12:50.179 -> Command = google20
16:12:50.179 -> String length = 8
16:12:50.179 -> timeSpanAsChar = 20
16:12:50.179 -> constructed URL = https://script.google.com/macros/s/AKfycbzt-p2UuSj-6cUdxoxOxNrCtvoCieO1Y4N6r8IxYpytoeGlly2O9XJLZo7I482YhjyytQ/exec?timeSpan=20
16:12:50.217 -> Getting Google Recycle calendar data...
16:12:56.442 -> checking response...
16:12:56.442 -> HTTP Response code: 200
16:12:56.442 -> Length of payload string: 321
16:12:56.442 -> Payload as String : {"status":"success","data":[{"TYPE":"RA","DATE":"2024-04-10T05:00:00.000Z"},{"TYPE":"PMD","DATE":"2024-04-10T05:00:00.000Z"},{"TYPE":"P/K","DATE":"2024-04-17T05:00:00.000Z"},{"TYPE":"GFT","DATE":"2024-04-17T05:00:00.000Z"},{"TYPE":"RA","DATE":"2024-04-24T05:00:00.000Z"},{"TYPE":"PMD","DATE":"2024-04-24T05:00:00.000Z"}]}
16:12:56.522 -> Length of payload char[]: 321
16:12:56.522 -> Payload as char [] : {"status":"success","data":[{"TYPE":"RA","DATE":"2024-04-10T05:00:00.000Z"},{"TYPE":"PMD","DATE":"2024-04-10T05:00:00.000Z"},{"TYPE":"P/K","DATE":"2024-04-17T05:00:00.000Z"},{"TYPE":"GFT","DATE":"2024-04-17T05:00:00.000Z"},{"TYPE":"RA","DATE":"2024-04-24T05:00:00.000Z"},{"TYPE":"PMD","DATE":"2024-04-24T05:00:00.000Z"}]}
16:12:56.529 -> Event #1 - TYPE: RA, Date: Wednesday, April 10 2024
16:12:56.529 -> Event #2 - TYPE: PMD, Date: Wednesday, April 10 2024
16:12:56.529 -> Event #3 - TYPE: P/K, Date: Wednesday, April 17 2024
16:12:56.529 -> Event #4 - TYPE: GFT, Date: Wednesday, April 17 2024
16:12:56.529 -> Event #5 - TYPE: RA, Date: Wednesday, April 24 2024
16:12:56.529 -> Event #6 - TYPE: PMD, Date: Wednesday, April 24 2024
16:12:56.550 -> Event #7 - TYPE: (, Date: Friday, May 03 2024
16:12:56.550 -> Event #8 - TYPE: xV��, Date: Friday, May 03 2024
16:12:56.550 -> Event #9 - TYPE: � , Date: Wednesday, May 08 2024
16:12:56.550 -> Event #10 - TYPE: 9000042Z 280128000042Z0G1 0 UUS1"0 U
16:12:56.550 -> Google Trust Services LLC10U GTS Root R10�"0 *�H�� , Date: Wednesday, May 08 2024
It appears that the data for the first 20 days are correct, but deserialization produces additional results (actually garbage) which are not contained in the payload string. Looks like deserialization is not starting from a clean slate?
