ArduinoJson (V7): How to serialize into Json object the array of struct?
I have array of struct
#include <ArduinoJson.h>
JsonDocument JSON_Obj;
struct MyStruct { int index; const char* EffectName; bool Selected; };
MyStruct MyArray[] =
    {1, "First",  false},
    {5, "Second", true},
    {3, "Third",  false},
How to serialize it into Json object, using ArduinoJson library V7 (by Benoit Blanchon) ?
That is what I've tried, but it is good only for one array item, do not know how to iterate over array...
JsonArray data = JSON_Obj["Array"].to<JsonArray>();
data.add(MyArray[0].index);
data.add(MyArray[0].EffectName);
data.add(MyArray[0].Selected);
P.S. Need to pass it over web-socket to parse on remote site by java-script to update options on "select" html control...
try something like this
JsonDocument doc;
MyStruct myArray[] =
const size_t myArrayCnt = sizeof myArray / sizeof * myArray;
  for (MyStruct& s: myArray) {
    JsonObject obj = doc.createNestedObject();
    obj["index"] = s.index;
    obj["EffectName"] = s.EffectName;
    obj["Selected"] =s.Selected;
  // Serialize JSON object to string
  String jsonString;
  serializeJson(doc, jsonString);
  Serial.println(jsonString);
void loop() {}
Yes, it works, thank you!
    "index": 1,
    "EffectName": "First",
    "Selected": false
    "index": 5,
    "EffectName": "Second",
    "Selected": true
    "index": 3,
    "EffectName": "Third",
    "Selected": false
But it creates whole section with no name, are there any way to add the name, like "Options": in front of this?
Ok, seems like I need to explain problem better.
Your solution (see above) works good if I have ONLY this array in json. If I have added some plain variable either before or after array - array completely disappear from json... Look on the code below, it gives me only: {"Var1":"ABCD","Var2":"before array","Var3":"after array"}.
Array appears in json only if I remove all other variables adding into json, before and after array.
So, my corrected question is: how to add array into json object along with other variables?
  delay(1000); //for stability
  Serial.println(); Serial.println();
  //Add plain variables
  JSON_Obj["Var1"] = String("ABCD");
  JSON_Obj["Var2"] = String("before array");
  //Add Array
  for (MyStruct& s: MyArray) {
    JsonObject obj = JSON_Obj.createNestedObject();
  //add more plain variables
  JSON_Obj["Var3"] = String("After array");
String jsonString;
serializeJson(JSON_Obj, jsonString);
I have done it in two different ways,:
  1. using JsonObject as object for whole array and JsonArray for each array item;
  2. using JsonArray bor both, for whole array and for each item.
See code below, you can comment out defines on the beginning to control which way to use...
const size_t MyArrayCnt = sizeof MyArray / sizeof * MyArray;
#define ExtObject_IntArray
//#define ExtObject_IntObject
  Serial.println();Serial.println();
  //Added plain variables
#ifdef ExtObject_IntArray
  //External JsonObject, Internal JsonArray
  JsonObject ExtObj1 = JSON_Obj["ArrayName1"].createNestedObject();
  for (uint8_t i=0; i<MyArrayCnt; i++)
    JsonArray IntArr1 = ExtObj1["ArrayIndex"+String(i)].to<JsonArray>();
    IntArr1.add(MyArray[i].index);
    IntArr1.add(MyArray[i].EffectName);
    IntArr1.add(MyArray[i].Selected);
#endif
#ifdef ExtObject_IntObject
  //External JsonObject, Internal JsonObject
  JsonObject ExtObj2 = JSON_Obj["ArrayName2"].createNestedObject();
    MyStruct s = MyArray[i];
    JsonObject IntObj2 = ExtObj2["ArrayIndex"+String(i)].createNestedObject();
    IntObj2["index"] = s.index;
    IntObj2["EffectName"] = s.EffectName;
    IntObj2["Selected"] =s.Selected;
#endif
  //added more plain variablex
  JSON_Obj["Var3"] = String("after array");
  String jsonString;
  //serializeJson(JSON_Obj, jsonString);
  serializeJsonPretty(JSON_Obj, jsonString);
First approach gives output like this:
  "Var2": "before array",
  "ArrayName1": [
      "ArrayIndex0": [
        1,
        "First",
        false
      "ArrayIndex1": [
        5,
        "Second",
        true
      "ArrayIndex2": [
        3,
        "Third",
        false
  "Var3": "after array"
The output of the second one is here:
  "ArrayName2": [
      "ArrayIndex0": [
          "index": 1,
          "Selected": false
      "ArrayIndex1": [
          "index": 5,
          "Selected": true
      "ArrayIndex2": [
          "index": 3,
          "Selected": false
I like first one more, less text :-). Now, I need to decode it on the java-script side.
Thanks to all.
Glad you solved it
