ArduinoNano and L298NDualHBridge 2 motors 1 joystick
Good day,
I am working on the sketch below and adjusted some lines to fit my needs but I noticed that the LEFT turn behaves differently then the RIGHT turn.
I have yet figured out the reason and looking for assistance.
the below is the sketch, I am looking to see why when moving joystick right the motor start at highspeed? The left turn is smooth depending on the joystick value.
How can I have the same behavior for both LEFT/RIGHT scenario?
Thank You
// Motor A
int enA = 9;
int in1 = 8;
int in2 = 7;
// Motor B
int enB = 3;
int in3 = 5;
int in4 = 4;
// Joystick Input
int joyVert = A0; // Vertical
int joyHorz = A1; // Horizontal
// Motor Speed Values - Start at zero
int MotorSpeed1 = 0;
int MotorSpeed2 = 0;
// Joystick Values - Start at 512 (middle position)
int joyposVert = 512;
int joyposHorz = 512;
  // Set all the motor control pins to outputs
  pinMode(enA, OUTPUT);
  pinMode(enB, OUTPUT);
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  pinMode(in3, OUTPUT);
  pinMode(in4, OUTPUT);
  // Start with motors disabled and direction forward
  // Motor A
  digitalWrite(enA, LOW);
  digitalWrite(in1, HIGH);
  digitalWrite(in2, LOW);
  // Motor B
  digitalWrite(enB, LOW);
  digitalWrite(in3, HIGH);
  digitalWrite(in4, LOW);
  // Read the Joystick X and Y positions
  joyposVert = analogRead(joyVert);
  joyposHorz = analogRead(joyHorz);
  if (joyposHorz < 460)
    // This is Left
    // Set Motor A backward
    digitalWrite(in1, LOW);
    digitalWrite(in2, HIGH);
    // Set Motor B forward
    //Determine Motor Speeds
    joyposHorz = joyposHorz - 460; // This produces a negative number
    joyposHorz = joyposHorz * -1;  // Make the number positive
    MotorSpeed1 = map(joyposHorz, 0, 460, 0, 255);
    MotorSpeed2 = map(joyposHorz, 0, 460, 0, 255);
  else if (joyposHorz > 564)
    //this is right
    // Set Motor A forward
    // Set Motor B backward
    digitalWrite(in3, LOW);
    digitalWrite(in4, HIGH);
    joyposHorz = joyposHorz + 564; // This produces a negative number
    joyposHorz = joyposHorz * 1;  // Make the number positive
    MotorSpeed1 = map(joyposHorz, 0, 564, 0, 255);
    MotorSpeed2 = map(joyposHorz, 0, 564, 0, 255);
    // Map the number to a value of 255 maximum
    joyposHorz = map(joyposHorz, 564, 1023, 0, 255);
    MotorSpeed1 = MotorSpeed1 + joyposHorz;
    MotorSpeed2 = MotorSpeed2 - joyposHorz;
    // Don't exceed range of 0-255 for motor speeds
    if (MotorSpeed1 > 255)MotorSpeed1 = 255;
    if (MotorSpeed2 < 0)MotorSpeed2 = 0;
  else if (joyposVert > 564)
    // This is Forward
    MotorSpeed1 = map(joyposVert, 564, 1023, 0, 255);
    MotorSpeed2 = map(joyposVert, 564, 1023, 0, 255);
  else if (joyposVert < 460)
    // This is Backward
    // As we are going backwards we need to reverse readings
    joyposVert = joyposVert - 460; // This produces a negative number
    joyposVert = joyposVert * -1;  // Make the number positive
    MotorSpeed1 = map(joyposVert, 0, 460, 0, 255);
    MotorSpeed2 = map(joyposVert, 0, 460, 0, 255);
    // This is Stopped
    MotorSpeed1 = 0;
    MotorSpeed2 = 0;
  // Adjust to prevent "buzzing" at very low speed
  if (MotorSpeed1 < 8)MotorSpeed1 = 0;
  if (MotorSpeed2 < 8)MotorSpeed2 = 0;
  // Set the motor speeds
  analogWrite(enA, MotorSpeed1);
  analogWrite(enB, MotorSpeed2);
Sorry, I can't make much sense of your calculations. If joyposHorz is > 564 why do you think that adding 564 to it is going to make it negative? And if it did how would multiplying it by 1 make it positive?
Steve
