Hi all, need help to get OTA on mega using ArduinoOTA.
Just flashed AT firmware on esp8266, serial monitor returns OK. Burned optiboot on mega too.
I don´t understand what´s next. How can I update sketches on mega from arduino ide?
In ArduinoOTA examples the WiFi101_OTA.ino seemed to me the right starting point but it was impossible compile the code, lot of errors:
In file included from C:\Users\Rosa\Documents\Arduino\libraries\WiFiNINA\src/WiFiStorage.h:23:0,
from C:\Users\Rosa\Documents\Arduino\libraries\WiFiNINA\src/WiFi.h:38,
from C:\Users\Rosa\Documents\Arduino\libraries\WiFiNINA\src/WiFiNINA.h:23,
from C:\Users\Rosa\Documents\Arduino\ARDUINO_OTA_BASE\ARDUINO_OTA_BASE.ino:22:
C:\Users\Rosa\Documents\Arduino\libraries\WiFiNINA\src/utility/wifi_drv.h:293:12: error: 'PinStatus' does not name a type
static PinStatus digitalRead(uint8_t pin);
Hi hammy, thank you for your help. I have followed the instructions from ArduinoOTA page where in the mega section it says:
The most common Arduino ATmega board with more than 64 kB of flash memory is Arduino Mega. To use it with ArduinoOTA library, you can't use it directly with the Arduino AVR package, because the package doesn't have the right fuse settings for Mega with Optiboot. You can download my boards definitions and use it to burn the modified Optiboot and to upload sketches to your Mega over USB and over network.
This basically indicates that the library that you're using is not for the board that you're using. PinStatus is used by some boards that are based on the 4809 processor (Nano Every and Uno WiFi rev2).
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project See About the IDE 1.x category.
