hier geht es um die Interrupts. Ich habe hier ein Beispielprogramm, das wie folgt aussieht:
** This software is in the public domain, furnished "as is", without technical
** support, and with no warranty, express or implied, as to its usefulness for
** any purpose.
** servoin_example.pde
** Demonstrate Servo Signal Input functionality
** Author: Daniel van den Ouden
** Project: ArduinoRCLib
** Website: http://sourceforge.net/p/arduinorclib/
#include <ServoIn.h>
#include <Timer1.h>
#define SERVOS 4
uint16_t g_values[SERVOS]; // output buffer for ServoIn
uint8_t g_workIn[SERVOIN_WORK_SIZE(SERVOS)]; // we need to have a work buffer for the ServoIn class
rc::ServoIn g_ServoIn(g_values, g_workIn, SERVOS);
// Initialize timer1
rc::Timer1::init();
// We use pin 8-11 as Servo input pins
pinMode(8, INPUT);
pinMode(9, INPUT);
pinMode(10, INPUT);
pinMode(11, INPUT);
// only allow pin change interrupts for PB0-3, digital pins 8-11.
PCMSK0 = (1 << PCINT0) | (1 << PCINT1) | (1 << PCINT2) | (1 << PCINT3);
// enable pin change interrupt 0
PCICR = (1 << PCIE0);
// start listening
g_ServoIn.start();
// update incoming values
g_ServoIn.update();
// handle servo values here, stored in g_values
// Interrupt handling code below, this needs cleaning
static uint8_t lastB = 0;
// Pin change port 0 interrupt
ISR(PCINT0_vect)
uint8_t newB = PINB;
uint8_t chgB = newB ^ lastB; // bitwise XOR will set all bits that have changed
lastB = newB;
if (chgB)
if (chgB & _BV(0))
g_ServoIn.pinChanged(0, newB & _BV(0));
if (chgB & _BV(1))
g_ServoIn.pinChanged(1, newB & _BV(1));
if (chgB & _BV(2))
g_ServoIn.pinChanged(2, newB & _BV(2));
if (chgB & _BV(3))
g_ServoIn.pinChanged(3, newB & _BV(3));
Nun wollte ich aber die Pins für den Eingang auf die Pins: 3, 11,12 und 13 umlegen. Das dies andere Ports, bzw. IRQ-Services hat, habe ich den Code wie folgt geändert:
** any purpose.
#include <Timer1.h>
#define SERVOS 4
rc::Timer1::init();
pinMode(3, INPUT);
pinMode(11, INPUT);
pinMode(12, INPUT);
pinMode(13, INPUT);
PCMSK0 = (1 << PCINT3) | (1 << PCINT4) | (1 << PCINT5); // IR für Pins 11, 12, 13
PCMSK2 = (1 << PCINT19); // IR for Pin 3
PCICR = (1 << PCIE1);
// start listening
g_ServoIn.start();
g_ServoIn.update();
for (int i = 0; i < SERVOS; i++) {
Serial.print(" Kanal: ");
Serial.print(i);
Serial.print(" = ");
Serial.print(g_values[i]);
Serial.println(" ");
static uint8_t lastD = 0;
ISR(PCINT2_vect)
uint8_t newD = PIND;
uint8_t chgD = newD ^ lastD; // bitwise XOR will set all bits that have changed
lastD = newD;
if (chgD)
if (chgD & _BV(0))
g_ServoIn.pinChanged(0, newD & _BV(0));
ISR(PCINT0_vect)
lastB = newB;
if (chgB)
if (chgB & _BV(0))
g_ServoIn.pinChanged(1, newB & _BV(0));
if (chgB & _BV(1))
g_ServoIn.pinChanged(2, newB & _BV(1));
if (chgB & _BV(2))
g_ServoIn.pinChanged(3, newB & _BV(2));
Aber irgendwie schlägt mein Vorhaben fehlt
Hat jemand einen Tipp für mich?
