Arduinos communication
We are working on our senior design and one difficulty is having an arduino wirelessly send a a message we preset when pressing a pushbutton.
The message goes to display on an lcd screen connected to a different arduino. We are using two arduinos and tried nrf24l01 modules but we have had poor luck with those.
Can you recommend any tutorial solutions or other wireless communicating devices to transfer text strings.??
Any help would be Appreciated!
Thanks,
Stramyyy
That sounds like a great idea! Unfortunately I am unable to assist but I am sure there is someone who can.
Keep up the good work!
That's a suspiciciously similar pair of IP addresses
Edit: what exactly is the Fenway?
There are many Threads in the Forum about NRF24 devices.
They seem to work well.
If you want advice post your code.
...R
Nrf24l01 are easy and cheap modules with decent range. Maybe yours are damaged? Try with simple examples to check if they work.
Other expensive solution is xbee, also easy.
You could try 433 Mhz.
433 Mhz to LCD tutorial works. You could change the code to send a predeclared string.
Oh thanks I checked out some of their posts,
The nrf modules work when doing the ping pair example
Also I am on my colleges wifi and the Fenway is Boston Park..
I am trying to modify one example on the forum here is the code compiles but the screen displays only the second string every set # seconds
RadioSend
- CONNECTIONS: nRF24L01 Modules See:
http://arduino-info.wikispaces.com/Nrf24L01-2.4GHz-HowTo
  1 - GND
  2 - VCC 3.3V !!! NOT 5V
  3 - CE to Arduino pin 9
  4 - CSN to Arduino pin 10
  5 - SCK to Arduino pin 13
  6 - MOSI to Arduino pin 11
  7 - MISO to Arduino pin 12
  8 - UNUSED
Send a series of zeros and ones to the receiver radio.
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
// NOTE: the "LL" at the end of the constant is "LongLong" type
const uint64_t pipe = 0xE8E8F0F0E1LL; // Define the transmit pipe
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
int high[1];
int low[1];
 radio.begin();
 radio.openWritingPipe(pipe);
 high[0] = 1;
 low[0] = 0;
 radio.write(high, sizeof(high));
 delay(3000);
 radio.write(low, sizeof(low));
 delay(3000);
Receiver
RadioReceive
  1 - GND
  8 - UNUSED
Receive a series of zeros and ones from the sender radio.
#include <SPI.h>
#include <RF24.h>
#include <SoftwareSerial.h>
#define CE_PIN   9
#define CSN_PIN 10
SoftwareSerial mySerial(8,1); // pin 1 = TX, pin 8 = RX (unused)
int received[1];
 pinMode(1,OUTPUT);
 mySerial.begin(9600);
  radio.begin();
  radio.openReadingPipe(1,pipe);
  radio.startListening();
}//--(end setup )---
  mySerial.write(254); // move cursor to beginning of first line
  mySerial.write(128);
  mySerial.write("                "); // clear display
 if ( radio.available() )
   // Read the data payload until we've received everything
   bool done = false;
   while (!done)
     // Fetch the data payload
     done = radio.read( received, sizeof(received) );
     if (received[0]== 0)
        mySerial.write("Good Morning");      // print text to LCD
        delay(5000);
        mySerial.write("I Miss You!");      // print text to LCD
        delay(5000);
What do you think might be the effect of delay(5000); ?
Why have you all that mySerial() stuff in the Receiver code ?
When you are trying to figure something out keep the code as simple as possible by displaying messages on the Serial Monitor.
...R
I don't see any pushbutton in the tranmit code or any lcd in the receive code. If I asssume that the "mySerial" code is for the LCD, that still leaves no pushbutton code in the Tx code. What's up with that ?
Thanks for the responses.
The myserial() code is for the LCD because we are using a serial LCD. In that example I was trying to get the transceivers to work without the push-buttons. I wrote a simple code to go from two push-buttons to LCD screen which works below.
The struggle is modifying this with the previous code to transmit the data to the corresponding LCD screen.
#include "nRF24L01.h"
#include "RF24.h"
#include <RF24_config.h>
#include <serLCD.h>
#include <SPI.h>
#include <LiquidCrystal.h>
// Attach the serial display's RX line to digital pin 2
#define buttononePin 6       // first button pin
#define buttontwoPin 7       // second button pin
int button1 = 0;              // declares variable for button input values
int button2 = 0;             // declares variable for button input values
      pinMode(buttononePin, INPUT);                // declare first button as input
      pinMode(buttontwoPin, INPUT);                // declare second button as input
      mySerial.begin(9600);  //set-up serial port
      delay(500); // wait for display to boot
  button1 = digitalRead(buttononePin);               // read first button input value and stores variable
  button2 = digitalRead(buttontwoPin);              // read second button input value and stores variable
   if (button1 == LOW)                               // if first button pressed
     mySerial.write("Good Morning!");      // print text to LCD
     delay(5000);
 if (button2 == LOW)                              //if second button pressed
     mySerial.write("I miss you! <3");         // print text to LCD
     delay(5000);
stramis:
I figured that.
What I was trying to suggest is that you don't use the LCD until you have the Tx and Rx code working - just so that the program is a simple as it possibly can be.
Get things working with the Serial Monitor and then add the LCD stuff later.
...R
The RF24 library has some example sketches, one of which (Remote Leds) monitors switches and lights leds associated with specific switches. You said your NRF24L01 works with the ping pong example (which has a different filename). If it works with that it should work with the switch example. If you use the switch example and combine it with CASE statements, you can send specific LCD messages based on the CASE processing of the received code for lighting the leds (which may be a binary or decimal number that represents the binary value of the switch positions at the Tx end).
As Robin pointed out, you should perform you testing from the bottom up, meaning verify communication first, lcd second. There may be an issue with your use of Tx & Rx pins with the USB cable connected to your computer. I have found that disconnecting the USB and running off external power after loading the sketch solves that issue since the Tx & Rx are linked to the FTDI chip and affected by those outputs.
raschemmel:
Unfortunately I am waiting on an 9V adapter to test this, but the LED_remote does not seem to work, when i hit either button the serial monitor says:
Now Sending: OK
but on the receiving side, the LED's stay lit the whole time, says got buttons..
Would you know how to troubleshoot this?
When I need to have debug feedback without a USB cable, I use an I2C LCD.
If the NRF24L01 modules work with one example , they should work with all of them.
The "Remote Leds" example should be the one with six switches at one end and six leds at the Rx end. There is also an example with one or two switches and one or two leds. Are you running the examples with no additional h/w or s/w added to validate the test setup ?
Thanks for all the help, we got a one directional code working with 2 push buttons to the LCD screen. The problem is the radio constantly sends the number we designate when a button is pressed. How do we make it so the receiver only writes to the LCD screen once per button push even with multiple radio firings?!?
Transmit:
#include <SPI.h>
#include "RF24.h"
int msg[1];
RF24 radio(9,10);
int SW1 = 7;
int SW2 = 6;
void setup(void)
 radio.begin();
void loop(void)
 if (digitalRead(SW1) == LOW){
 msg[0] = 111;
 radio.write(msg, 1);}
 delay(10);
 if (digitalRead(SW2) == LOW){
 msg[0] = 222;
Receiver:
#include <serLCD.h>
#include <SPI.h>
#include "RF24.h"
int msg[1];
RF24 radio(9,10);
SoftwareSerial mySerial(8,2); // pin 1 = TX, pin 8 = RX (unused)
void setup(void){
 radio.begin();
void loop(void){
 if (radio.available()){
   bool done = false;
   while (!done){
     done = radio.read(msg, 1);
     Serial.println(msg[0]);
     if (msg[0] == 111){delay(100);
     mySerial.write("Good Morning!");}
     delay(5000);
     if (msg[0] == 222){delay(100);
     mySerial.write("I Miss You!");}
     delay(5000);}}}
My specialty isn't S/W (it's H/W) but if I had to do it I would probably use BOOLEAN flags:
PSEUDO CODE
IF (switchflag ==true)
[write message;
delay;
clear switchflag;]
By the time you clear the switch flag you will have released the button many seconds ago so the code should not display a second time.
Maybe the S/W experts have some other suggestion, but that's mine.
I agree with @raschemmel - but if there is a need for an interval between updates don't use delay() - use millis() as illustrated in several things at a time
It is much easier to use millis() right from the start rather than trying to modify the code to replace delay() functions at a later time.
Another option, which eliminates the need for any interval, is to update the LCD only when the data has changed. That way 100 similar messages will only cause one update.
...R
I agree with Robin2, use millis() and update on data change. Try flags first then when that works correctly save it as "FLAGS" then change it to update on data change and compare that with the fiags approach
Thanks for those suggestions! What we ended up doing was adding a simple for loop for the transmit side, so that the receiver side will only read the specific value once per button press.
The next step for us is to make this bi-directional! Unfortunately combining the code does not seem to be a quick solution.. any suggestions there.?!
We do have another pair of nrf24l01 if they should be required.
Transmitter
#include <serLCD.h>
#include <SPI.h>
#include "RF24.h"
int msg[1];
RF24 radio(9,10);
int SW1 = 7;
int SW2 = 6;
void setup(void)
 radio.begin();
void loop(void)
 for (int x=0;x<4;x++){
 msg[0] = x;
 delay(10);
 for (int x=5;x<9;x++){
 msg[0] = x;
 delay(10);
Reciever
#include <serLCD.h>
#include <SPI.h>
#include "RF24.h"
int msg[1];
RF24 radio(9,10);
void setup(void)
 radio.begin();
void loop(void){
   bool done = false;
   while (!done){
     if (msg[0] == 1){delay(100);
     if (msg[0] == 6){delay(100);
     delay(1500);}
