Arduino's ground
I’m soldering up a proto board, and I was wondering if I can just solder the negative lead from my battery pack to the ground on the proto board instead of soldering it to a 2.1 mm plug. I tested the negative side of the 2.1 mm plug, and found it connects to the ground on the prototype board I’m making, so it appears I can do this. But I’m not sure if there is some internal protection or reason to apply power to the socket instead.
yes
