You want to have the data real time?
Is there line of sight between the nodes?
How much data per second per node do you expect?
How much nodes are there?
Are the nodes identical?
Are the nodes inside or outside?
Is there an open network in the neighbourhood you are allowed to use?
-> YES and NO .... I need detect problems ... if I detect problems sooner lose less money .. Is there line of sight between the nodes?
-> No!! How much data per second per node do you expect?
I need to read a temperature sensor (for example) and get the data (the speed is not important)!. How much nodes are there?
-> one between 500 to 1000 meters Is there an open network in the neighbourhood you are allowed to use?
No...
