Arduino's server isn't loading
I'm trying to get a server working that allows my Arduino to send temperature data every 2 minutes. I was able to get the server to work with the temperature data being sent every millisecond, but the moment I tried to make It send every 2 minutes using the milis() function, the server just would be on an infinite load. On top of this, the server will only load correctly if client.stop() is in the code.
#include <WiFiNINA.h>
#include "Adafruit_Sensor.h"
#include "Adafruit_AM2320.h"
char ssid[] = "---";             // your network SSID (name) between the ""
char pass[] = "----";      // your network password between the ""
int keyIndex = 0;                 // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;      // connection status
WiFiServer server(80);            // server socket
WiFiClient client;
Adafruit_AM2320 am2320 = Adafruit_AM2320();
int ledPin = 2;
unsigned long previousMillis = 0;   // will store last time temperature was sent
const long interval = 10000;        // interval at which to send temperature (milliseconds)
  pinMode(ledPin, OUTPUT);
  while (!Serial);
  enable_WiFi();
  connect_WiFi();
  server.begin();
  am2320.begin();
  printWifiStatus();
  // Initialize previousMillis
  previousMillis = millis();
  client = server.available();
  // Check if it's time to send temperature
  if (currentMillis - previousMillis >= interval) {
    // Save the last time you sent temperature
    if (client) {
      Serial.print("Client connected");
      // Prepare HTTP response
       // blank line indicates end of headers
      // Send temperature data
      client.print(am2320.readTemperature());
      Serial.print(am2320.readTemperature());
      Serial.print("Sending temperature");
      // Close the connection after response (optional)
  // Handle other tasks or conditions here
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
  Serial.print("To see this page in action, open a browser to http://");
  Serial.println(ip);
void enable_WiFi() {
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < "1.0.0") {
    Serial.println("Please upgrade the firmware");
void connect_WiFi() {
  // attempt to connect to Wifi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
Move the server-updating line into the rate-limited conditional statement:
