Arduino's Supply
(deleted)
Basically yes.
But it depends on what you connect to the Uno's 5V and 3.3V pins and the pins configured as output.
The on-board voltage regulator converts the product of voltage drop (12V - 5V) and the needed current to heat and there is a limit to what it can handle.
(deleted)
Vin is the input used for the 7V (or higher) power supply. It provides the same function as the barrel jack on the board.
