Arduinos talking to eachother through ethernet and to the world through internet
What is displayed on the web browser when you make this request?
You are not checking if the file open worked. Try adding some error checking.
                        webFile = SD.open("index.htm");
                        if (webFile) {
                            while(webFile.available()) {
                                client.write(webFile.read()); // send web page to client
                            webFile.close();
                        else {
                            Serial.println(F("SD open fail"));
                            client.println(F("<html><body>SD open fail</body></html>"));
That is a very inefficient way of sending that file. You should buffer a few characters from the sd read before sending a packet.
edit: Are you sure that array is big enough to hold the request? Web browser requests can be quite large.
#define REQ_BUF_SZ   60
Here is my web server code. It saves only the GET line, and ignores the rest of the request header.
http://playground.arduino.cc/Code/WebServerST
The web broswer shows one character repeating all over the place.
The same code on a duemiglianove and ethernet shield works fine for weeks. thats why i tried the same code.
What character? The only thing you are sending is the header and the index.htm file. Are you certain the file opened? Try the error checking I suggested above.
I use the Mega, w5100, and SD together and they all work fine.
edit: The character isn't the "funny y", is it? This character: ÿ
yes it is! the damn y!
edit: it is an overflow? but why? and why on web and not on the serial? and why the same code works on duemiglianove?
Then your file open probably failed. The "funny y" is -1 (fail or no character available).
so a faulty sd card or socket? yes?
can you help me ask the server above for the state of d2 for example. what should i put in the get command? I am getting there but something is wrong.
Maybe. It could also be the file contents are corrupt. Replace that SD file read with a standard "Got it!" message.
                        client.println("Content-Type: text/html");
                        client.println("Connection: keep-alive");
                        client.println();
                        client.println("<html><body>Got it!</body></html>");
                        // then comment out the SD.open()
If that works, you might want to try just a file read sketch to test the index.htm file and contents. See if you can get it to display on the serial monitor.
If you are using a Mega, you should not be running out of SRAM, but that would also produce that result. If you are using an Uno R3, you may be running out of SRAM. Try the F() function to reduce your SRAM use. Like this:
                        client.println(F("Content-Type: text/html"));
                        client.println(F("Connection: keep-alive\r\n"));
                        // I put the \r\n in the send above so it goes in that packet.
                        client.println(F("<html><body>Got it!</body></html>"));
with this
#include <SD.h>
// On the Ethernet Shield, CS is pin 4. Note that even if it's not
// used as the CS pin, the hardware CS pin (10 on most Arduino boards,
// 53 on the Mega) must be left as an output or the SD library
// functions will not work.
const int chipSelect = 4;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("Initializing SD card...");
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(10, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  Serial.println("card initialized.");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("index.htm");
  // if the file is available, write to it:
  if (dataFile) {
    while (dataFile.available()) {
      Serial.write(dataFile.read());
    dataFile.close();
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening datalog.txt");
i got all the file in the serial
Initializing SD card...card initialized.
<!DOCTYPE html>
<html>
    <head>
        <title>Arduino Ajax I/O</title>
        <script>
		strLED1 = "";
		strLED2 = "";
		strLED3 = "";
		strLED4 = "";
		var LED3_state = 0;
		var LED4_state = 0;
		function GetArduinoIO()
			nocache = "&nocache=" + Math.random() * 1000000;
			var request = new XMLHttpRequest();
			request.onreadystatechange = function()
				if (this.readyState == 4) {
					if (this.status == 200) {
						if (this.responseXML != null) {
							// XML file received - contains analog values, switch values and LED states
							var count;
							// get analog inputs
							var num_an = this.responseXML.getElementsByTagName('analog').length;
							for (count = 0; count < num_an; count++) {
								document.getElementsByClassName("analog")[count].innerHTML =
									this.responseXML.getElementsByTagName('analog')[count].childNodes[0].nodeValue;
							// get switch inputs
							var num_an = this.responseXML.getElementsByTagName('switch').length;
								document.getElementsByClassName("switches")[count].innerHTML =
									this.responseXML.getElementsByTagName('switch')[count].childNodes[0].nodeValue;
							// LED 1
							if (this.responseXML.getElementsByTagName('LED')[0].childNodes[0].nodeValue === "checked") {
								document.LED_form.LED1.checked = true;
							else {
								document.LED_form.LED1.checked = false;
							// LED 2
							if (this.responseXML.getElementsByTagName('LED')[1].childNodes[0].nodeValue === "checked") {
								document.LED_form.LED2.checked = true;
							else {
								document.LED_form.LED2.checked = false;
							// LED 3
							if (this.responseXML.getElementsByTagName('LED')[2].childNodes[0].nodeValue === "on") {
								document.getElementById("LED3").innerHTML = "LED 3 is ON (D8)";
								LED3_state = 1;
							else {
								document.getElementById("LED3").innerHTML = "LED 3 is OFF (D8)";
								LED3_state = 0;
							// LED 4
							if (this.responseXML.getElementsByTagName('LED')[3].childNodes[0].nodeValue === "on") {
								document.getElementById("LED4").innerHTML = "LED 4 is ON (D9)";
								LED4_state = 1;
							else {
								document.getElementById("LED4").innerHTML = "LED 4 is OFF (D9)";
								LED4_state = 0;
			// send HTTP GET request with LEDs to switch on/off if any
			request.open("GET", "ajax_inputs" + strLED1 + strLED2 + strLED3 + strLED4 + nocache, true);
			request.send(null);
			setTimeout('GetArduinoIO()', 1000);
			strLED1 = "";
			strLED2 = "";
			strLED3 = "";
			strLED4 = "";
		// service LEDs when checkbox checked/unchecked
		function GetCheck()
			if (LED_form.LED1.checked) {
				strLED1 = "&LED1=1";
			else {
				strLED1 = "&LED1=0";
			if (LED_form.LED2.checked) {
				strLED2 = "&LED2=1";
			else {
				strLED2 = "&LED2=0";
		function GetButton1()
			if (LED3_state === 1) {
				LED3_state = 0;
				strLED3 = "&LED3=0";
			else {
				LED3_state = 1;
				strLED3 = "&LED3=1";
		function GetButton2()
			if (LED4_state === 1) {
				LED4_state = 0;
				strLED4 = "&LED4=0";
			else {
				LED4_state = 1;
				strLED4 = "&LED4=1";
	</script>
	<style>
		.IO_box {
			float: left;
			margin: 0 20px 20px 0;
			border: 1px solid blue;
			padding: 0 5px 0 5px;
			width: 120px;
		h1 {
			font-size: 120%;
			color: blue;
			margin: 0 0 10px 0;
		h2 {
			font-size: 85%;
			color: #5734E6;
			margin: 5px 0 5px 0;
		p, form, button {
			font-size: 80%;
			color: #252525;
		.small_text {
			font-size: 70%;
			color: #737373;
	</style>
    </head>
    <body onload="GetArduinoIO()">
        <h1>Arduino Ajax I/O</h1>
        <div class="IO_box">
			<h2>Analog Inputs</h2>
			<p class="small_text">A0 used by Ethernet shield</p>
			<p class="small_text">A1 used by Ethernet shield</p>
			<p>A2: <span class="analog">...</span></p>
			<p>A3: <span class="analog">...</span></p>
			<p>A4: <span class="analog">...</span></p>
			<p>A5: <span class="analog">...</span></p>
		</div>
			<h2>Switch Inputs</h2>
			<p class="small_text">D0: used by serial RX</p>
			<p class="small_text">D1: used by serial TX</p>
			<p>Switch 1 (D2): <span class="switches">...</span></p>
			<p>Switch 2 (D3): <span class="switches">...</span></p>
			<p class="small_text">D4: used by Ethernet shield</p>
			<p>Switch 3 (D5): <span class="switches">...</span></p>
		</div>
			<h2>LEDs Using Checkboxes</h2>
			<form id="check_LEDs" name="LED_form">
				<input type="checkbox" name="LED1" value="0" onclick="GetCheck()" />LED 1 (D6)
				<input type="checkbox" name="LED2" value="0" onclick="GetCheck()" />LED 2 (D7)
			</form>
		</div>
			<h2>LEDs Using Buttons</h2>
			<button type="button" id="LED3" onclick="GetButton1()">LED 3 is OFF (D8)</button>
			<button type="button" id="LED4" onclick="GetButton2()">LED 4 is OFF (D9)</button>
			<p class="small_text">D10 to D13 used by Ethernet shield</p>
		</div>
    </body>
</html>
i think the problem is when i use ethernet and sd together.
Then I put my money on SRAM depletion. You probably are running out of SRAM. Use the F() function on all your static strings, both Serial and client.
If that doesn't work, then you should check your SRAM use. I use a function freeRam() to check. I call it just before a function call that is failing. Add this freeRam() function to your code and call it just before the SD.open() call. How much does it say you have left?
int freeRam() {
  extern int __heap_start,*__brkval;
  int v;
  return (int)&v - (__brkval == 0 ? (int)&__heap_start : (int) __brkval);
  Serial.print(F("SRAM = "));
  Serial.println(freeRam());
does uno have less ram than duemilanove? i am telling you, i run this code on it for weeks.
i tried a mega on the same shield with no luck.. funny y
on the mega i have sram=6059 and on uno 425 both with yyys
Both should have the same SRAM. What version IDE are you using? I had real problems with the w5100 on versions prior to v1.0.1.
The "funny y" is a failure indication. Either the device is not responding or there are no characters available.
ubuntu and 1.0.3
same results with windows and 1.0.5
Try this code and watch the serial monitor. Does it work ok?
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
byte mac[] = { 0x8A, 0xF1, 0x24, 0xAA, 0x7F, 0x59 };
IPAddress ip(192, 168, 2, 126);
EthernetServer server(9999);
File webFile;
char HTTP_req[REQ_BUF_SZ] = {0};
char req_index = 0;
boolean LED_state[4] = {0};
    digitalWrite(10, HIGH);
    Serial.println("Initializing SD card...");
    if (!SD.begin(4)) {
        Serial.println("ERROR - SD card initialization failed!");
        return;
    Serial.println("SUCCESS - SD card initialized.");
    if (!SD.exists("index.htm")) {
        Serial.println("ERROR - Can't find index.htm file!");
        return;
    Serial.println("SUCCESS - Found index.htm file.");
    pinMode(2, INPUT);
    pinMode(3, INPUT);
    pinMode(5, INPUT);
    pinMode(6, OUTPUT);
    pinMode(7, OUTPUT);
    pinMode(8, OUTPUT);
    pinMode(9, OUTPUT);
    Ethernet.begin(mac, ip);
    server.begin();
    if (client) {  // got client?
        boolean currentLineIsBlank = true;
        while (client.connected()) {
            if (client.available()) {
                char c = client.read();
                if (req_index < (REQ_BUF_SZ - 1)) {
                    HTTP_req[req_index] = c;
                    req_index++;
                if (c == '\n' && currentLineIsBlank) {
                    if (StrContains(HTTP_req, "ajax_inputs")) {
                        Serial.println(F("ajax page request"));
                        client.println("Content-Type: text/xml");
                        client.println();
                        SetLEDs();
                        XML_response(client);
                    else {  // web page request
                        Serial.println(F("web page request"));
                        client.println("Connection: close");
                        client.println();
                        client.println(F("<html><body>Got the request!</body></html>"));
                    Serial.print(HTTP_req);
                    req_index = 0;
                    StrClear(HTTP_req, REQ_BUF_SZ);
                if (c == '\n') {
                else if (c != '\r') {
                    currentLineIsBlank = false;
        delay(1);
        Serial.println(F("Disconnecting"));
        client.stop();
void SetLEDs(void)
    if (StrContains(HTTP_req, "LED1=1")) {
        LED_state[0] = 1;  // save LED state
        digitalWrite(6, HIGH);
    else if (StrContains(HTTP_req, "LED1=0")) {
        LED_state[0] = 0;  // save LED state
        digitalWrite(6, LOW);
    if (StrContains(HTTP_req, "LED2=1")) {
        LED_state[1] = 1;  // save LED state
        digitalWrite(7, HIGH);
    else if (StrContains(HTTP_req, "LED2=0")) {
        LED_state[1] = 0;  // save LED state
        digitalWrite(7, LOW);
    if (StrContains(HTTP_req, "LED3=1")) {
        LED_state[2] = 1;  // save LED state
        digitalWrite(8, HIGH);
    else if (StrContains(HTTP_req, "LED3=0")) {
        LED_state[2] = 0;  // save LED state
        digitalWrite(8, LOW);
    if (StrContains(HTTP_req, "LED4=1")) {
        LED_state[3] = 1;  // save LED state
        digitalWrite(9, HIGH);
    else if (StrContains(HTTP_req, "LED4=0")) {
        LED_state[3] = 0;  // save LED state
        digitalWrite(9, LOW);
void XML_response(EthernetClient cl)
    int analog_val;
    int count;
    int sw_arr[] = {2, 3, 5};
    cl.print("<?xml version = \"1.0\" ?>");
    cl.print("<inputs>");
    // read analog inputs
    for (count = 2; count <= 5; count++) { // A2 to A5
        analog_val = analogRead(count);
        cl.print("<analog>");
        cl.print(analog_val);
        cl.println("</analog>");
    for (count = 0; count < 3; count++) {
        cl.print("<switch>");
        if (digitalRead(sw_arr[count])) {
            cl.print("ON");
        else {
            cl.print("OFF");
        cl.println("</switch>");
    cl.print("<LED>");
    if (LED_state[0]) {
        cl.print("checked");
    else {
        cl.print("unchecked");
    cl.println("</LED>");
    cl.print("<LED>");
    if (LED_state[1]) {
    else {
    cl.print("<LED>");
    if (LED_state[2]) {
        cl.print("on");
    else {
        cl.print("off");
    cl.print("<LED>");
    if (LED_state[3]) {
        cl.print("on");
    else {
        cl.print("off");
    cl.print("</inputs>");
void StrClear(char *str, char length)
    for (int i = 0; i < length; i++) {
        str[i] = 0;
char StrContains(char *str, char *sfind)
    char found = 0;
    char index = 0;
    char len;
    len = strlen(str);
    if (strlen(sfind) > len) {
        return 0;
    while (index < len) {
        if (str[index] == sfind[found]) {
            found++;
            if (strlen(sfind) == found) {
                return 1;
        else {
            found = 0;
        index++;
    return 0;
it seems that the sd is killed. cant read it on the pc, dont know if arduino killed it. i will find another and will try your code. thank you very much for your help!!
I killed my sd card a while back. It failed testing code here on the forum. I forgot to disable or remove the SD card when testing someone's w5100 code, and the format got screwed up.
Yes m8, if you check zoomcats test code above, it doesnt include a pin 10 high and my sd got fried...
:zipper_mouth_face:
Are you certain it fried it? It may be like mine. A reformat should take care of that if the SD card itself was not physically damaged.
pc wont see it. format with an arduino suggesting you are?
bleo8onhs:
That is not a good sign.
edit: The MISO line on the SD card may be damaged.
