ArduinoUNO Based 4-digit Temperature Meter (Complete Project)
This posting contains Circuit diagram (Response #2) , Control Program Flow Chart (Response #4), and program to convert ArduinoUNO Learning Kit into a 4-Digit Temperature Meter. It has used HMS-20G type Temperature Sensor with the following two point responses:
A(0.93V, 27.50 degC), B(0.84V, 25.80 degC) as per data sheets of HMS-20G
BINT (10^6*BCDT) = 16875h * VHT + 978510h ; derived by the author based on the given points
TMeterWorking.ino (7.39 KB)
You really need to attach a circuit diagram and show what type of sensor its designed for.
Please find the attached file for the Circuit Diagram and the HMS-20G type Temperature Sensor.
CircuitDiagramTempMeter.doc (645 KB)
(deleted)
The attached file contains Flow Chart for the Control Program of ArduinoUNO based Temperature Meter.
TMCPFlw.doc (499 KB)
