ArduinoUno - Time needed for each C instruction ?
Hi all,
i need to synchronize my arduino with another IC modem and i need to know how many time is needed for execute "each C instruction".
Looking the ATMEGA328 Datasheet I've seen that each "low level" instruction take 1/16000 more or less 62.5 nano second ...
but how many time takes ,
int i = 0;
i = i + 1;
or Serial.print(i) ?
Thanks for the info,
Gnux
The Arduino doesn't execute C instructions. The compiler converts the C instructions of machine instructions, and then optimizes them. The linker links them all together to form an executable. You will have a very difficult time determining how long "a C instruction" takes to execute, since many turn into more than one machine instruction.
i = 0;
is going to take a different amount of time than
i++;
will take, and
Serial.print(i);
will take a different amount to time depending on whether there is room in the outgoing buffer, or not.
In short, you can't get what you are asking for.
you need to look at the compiled code assembly. C/C++ code has little relationship to actual code size.
For example, in your example, int i will most probably evaporate into a single load instruction.
You can search your IDE installation for 'avr-objdump.exe', it will have a help screen you can view.
This is how I do it in windows and the 1.5.2 IDE ( using a bat file in shell:SendTo ):
D:\arduino-1.5.2\hardware\tools\avr\bin\avr-objdump.exe -S %1 > %1%.txt
Use micros() to synchronize?
As others have said, how long it takes to execute a 'line' of code really depends on what the line is and how it is compiled.
You can get an idea by doing something like:
startTime = micros();
…..line of code here…..
executeTime = micros()-startTime;
I don't think this will be accurate enough for consistently syncing two devices. can you use the i2c interface or a signal on a digital pin?
gnusso:
another IC modem
Part number?
Generally there will be a way of synchronising comms that doesn't involve counting clock cycles.
HI ALL the IC MODEM IS ST7540
in attachment the data sheet seems that are necessary for registry control write 525 microsecond before to accept the data ...
thanks for help,
Andrea
st7540.pdf (384 KB)
