Ardunio + Flash + BlueSmirf Problem
I recently got the flash demo I found at http://memewire.com/reference/Arduino_Flash
working through usb. Basically the program just turns LED's on and off through some buttons in
flash. I tried substituting the usb with my bluesmirf but the data that is transfered seems to be
messed up.
I am using the OS X version of serialproxy which i modified
serial_device1=/dev/cu.SparkFun-BT-COM0-1
Port 1 settings (ttyS0)
net_port1=5331
This seems to work as the bluesmirf's red LED lights up.
Normally in flash i get good output but when i change it over to the bluesmirf i get:
Arduino says -- ¾[ch65533]¾[ch65533]¾[ch65533]¾
Any ideas anyone?
Baud rate setting maybe? I know it is different for the BT.
when you get these values there are mostly the wrong bautrates!
usb arduino normaly has a ~9600 bautrate
bluetooth arduino has a ~115000 bautrate
Hello
A quick clarification: The Official Arduino BT is NOT the bluesmirf module sold by sparkfun
any question regarding that board should be posted on the Sparkfun forums...
Arduino BT uses a different Bluetooth module and has different requirements..
At the moment there is a proliferation of arduino "compatible" boards and support is becoming an issue....
