Ardunio is not accepting integers bigger than 9
any one know why the servo is not running when i sent he numbers through serial ?
when i used numbers less than 10 it works
#include <Servo.h>
Servo myservo;
  myservo.attach(9); //analog pin 0
  myservo.write(90);
  myservo.detach();
 int ch = Serial.read();
   switch(ch) {
      case '10':
        myservo.write(10);
      case '20':
        myservo.write(20);
       case '30':
        myservo.write(30);
This only receives 1 character
See asciitable.com
maybe change cases to:
case 'a':
case 'b':
case 'c':
Or, read in 2 digits:
void loop(){
if (Serial.available()>1){ // 2 characters came in?
digit1 = Serial.read() - 48; // read & convert to decimal, '0' to '9' expected
digit2 = Serial.read() - 48;
total = (digit1 *10) + digit2; // maybe swap these 2, result is 0 to 99
switch(total){
case 0:
case 99:
} // end switch
} // end serial checl
} // end loop
Not again. This topic only comes up about 8 times a day. Clearly, you've done NO searching.
CrossRoads:
See asciitable.com
case 'a':
case 'b':
case 'c':
void loop(){
switch(total){
case 0:
case 99:
} // end switch
} // end loop
thanks bro that was so helpfull
